QUEBEC--Trail Scouting Day June 27th--NEW DATE
Re: QUEBEC--Trail Scouting Day June 27th--NEW DATE
K, HOW MANY ARE WE 24 <img src='http://www.canadianhummerclub.com/forum ... iggrin.gif' class='bbc_emoticon' alt=':D' /> <img src='http://www.canadianhummerclub.com/forum ... iggrin.gif' class='bbc_emoticon' alt=':D' /> <img src='http://www.canadianhummerclub.com/forum ... iggrin.gif' class='bbc_emoticon' alt=':D' /> <img src='http://www.canadianhummerclub.com/forum ... iggrin.gif' class='bbc_emoticon' alt=':D' /> <img src='http://www.canadianhummerclub.com/forum ... >/wink.gif' class='bbc_emoticon' alt=';)' /> <img src='http://www.canadianhummerclub.com/forum ... >/wink.gif' class='bbc_emoticon' alt=';)' />
- hummerht
[quote author=whitehumh2 link=topic=1124.msg9637#msg9637 date=1245239361]
One suggestion I have for all us H2 and H3 guys, we NEED to extend our vent lines to minimum the height of our intakes in order to protect our diffs, t-case and tranny. Just some rubber hose and some tie-wraps and a little patience to route the hosing and we are ready for Submarine driver training!!! LOL! <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> I am working on two solutions for us H2 guys to keep our engines safe and will keep you all posted! Also everyone should get a 6ft br 9ft tarp from the local hardware store so that we can seal the front of our engine bays to make the wave in front of us and to minimize the water in the engine compartment and debris in the rads! BTW, you need some bungees too!
[/quote]Kevin i don't understand what is the rubber hose for <img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt='???' />
Stef the rubber hose is to extend the vents for the front diff, tranny and transfer case so that water doesn't go into those parts. The rear diff is good as it extends to the gas cap area, but could be run to the front to make it safer. The front diff, tranny and t-case vents are pathetic and need to be extended alot to ensure no water in those parts, best place to run them to is the air filter housing or at least the top of the engine compartment. Also, you need some tarps that are shaped to the front of your H2 to stop the water from going into the rads, TC and Roy you guys should do this also as it will help eliminate cleaning of the rads after the trail. BTW, these tarps will only be on for the water crossing to protect the engines and then removed to prevent over heating!
I HAVE SOME OLD HOSES WE CAN USE <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> <img src='http://www.canadianhummerclub.com/forum ... >/wink.gif' class='bbc_emoticon' alt=';)' /> <img src='http://www.canadianhummerclub.com/forum ... >/wink.gif' class='bbc_emoticon' alt=';)' />
ARE WE ON FOR THE WEEKEND?<img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt='???' />?<img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt='???' />??? AND WHO IS COMING DOWN
ONTARIO
ROY.....IN
DEREK?
MARKUS?
QUEBEC
KEVIN....IN
TONY...IN
ALAIN...IN
HUMMERHT2..?
CITIBOY..?
NEXT?<img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt='???' />??
ONTARIO
ROY.....IN
DEREK?
MARKUS?
QUEBEC
KEVIN....IN
TONY...IN
ALAIN...IN
HUMMERHT2..?
CITIBOY..?
- hummerht2
IM IN <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' />
ARE WE ON FOR THE WEEKEND?? AND WHO IS COMING DOWN
ONTARIO
ROY.....IN
DEREK?
MARKUS?
QUEBEC
KEVIN....IN
TONY...IN
ALAIN...IN
HUMMERHT2...IN
CITIBOY..?
NEXT???
ONTARIO
ROY.....IN
DEREK?
MARKUS?
QUEBEC
KEVIN....IN
TONY...IN
ALAIN...IN
HUMMERHT2...IN
CITIBOY..?
NEXT???
Where is all those from Ontario? got to be more than one crazy off roader!! <img src='http://www.canadianhummerclub.com/forum ... #>/sad.gif' class='bbc_emoticon' alt=':(' />
I ONLY KNOW YOU BRO.......YOUR THE BEST <img src='http://www.canadianhummerclub.com/forum ... /smile.gif' class='bbc_emoticon' alt=':)' /> <img src='http://www.canadianhummerclub.com/forum ... /smile.gif' class='bbc_emoticon' alt=':)' />
- citiboy
I'M IN, i wouldn't miss this trail run that's for sure <img src='http://www.canadianhummerclub.com/forum ... >/wink.gif' class='bbc_emoticon' alt=';)' /> <img src='http://www.canadianhummerclub.com/forum ... >/wink.gif' class='bbc_emoticon' alt=';)' /> <img src='http://www.canadianhummerclub.com/forum ... >/wink.gif' class='bbc_emoticon' alt=';)' />
