OEM air compressor repair????
kmleong
Post by kmleong »
I have an oem air compressor with the valve stuck in the open position. ie; it will pump air but it will leak back out. Does anyone know where I can send this for repair? I am in Vancouver. Maybe any ideas on how to repair this myself?
Thanks. Dennis
Re: OEM air compressor repair????
You can repair it quite easily yourself but you will need the OEM pressure valve block and some basic tools, the rest is pretty straight forward.
kmleong
Post by kmleong »
[quote author=whitehumh2 link=topic=1354.msg11408#msg11408 date=1256557565]
[/quote]can you direct me to where I can purchase the pressure valve block?
Thanks, Dennis
Better than a Valve Block, here is what I did. I got an entirely new suspension compressor assembly from one of the  other guys on the forum, but he only had one. So try the following link
http://www.arnottindustries.com/part_HU ... id441.html
Hope this helps,
kmleong
Post by kmleong »
Thanks for the quick reply. I don't have air suspension, but want to install it just to have an onboard compressor. Maybe it will work as is, just as a compressor on a switch. Thanks again for your advice, Dennis
