H3 Exhaust smell on cold start
studiotheater
Post by studiotheater »
My 2006 H3 with the 3.5 motor has exhaust fumes that smell similar to raw gasoline and this occurs on the first start up only after it has been sitting all nite. I am not getting a check engine lite so I am a bit puzzled what is going on; so I thought I would check to see if anyone else has come up against this problem.
Sugarphreak
Re: H3 Exhaust smell on cold start
Post by Sugarphreak »
Mine does the same thing actually, although I usually don't drive it for a week or two at a time.
Strange - I usually start my Hummer from the inside so I don't smell a thing.....  <img src='http://www.canadianhummerclub.com/forum ... iggrin.gif' class='bbc_emoticon' alt=':D' />
On a more serious note - common during the colder months as the EFI pumps additional gas in on cold starts so as long as you don't see any black smoke - then you should be fine.
