H1 & H2 Comparison
Re: H1 & H2 Comparison
Be Carefull Oh Great And Mighty D'Man is learning electronics and math. He may try and make an Electric Hummer. <img src='http://www.canadianhummerclub.com/forum ... lleyes.gif' class='bbc_emoticon' alt=':rolleyes:' /> SHOCKING!!!
- cbrandson
well iam going bit on this comparing H1 to H2 is like comparing hot supermodel to hot supermodel
[quote name='cbrandson' date='22 March 2010 - 04:43 PM' timestamp='1269294232' post='14994']
<img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
- spies
Why do all the guy's who have H 2's and 3's need to add, change or modify their trucks to try and compete with the H1's? The way I see it, it's like owning a turd, no matter how much you polish it, it's still just a turd!
[quote name='2N3RNFG' date='24 March 2010 - 03:29 PM' timestamp='1269462543' post='15122']
<img src='http://www.canadianhummerclub.com/forum ... feSpit.gif' class='bbc_emoticon' alt=':coffeespit:' /> <img src='http://www.canadianhummerclub.com/forum ... feSpit.gif' class='bbc_emoticon' alt=':coffeespit:' /> <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' /> <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' /> <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
[quote name='2N3RNFG' date='24 March 2010 - 09:29 PM' timestamp='1269462543' post='15122']
Actually ALL Hummer Owners Modify their Trucks! Afterall unless you have a 2003 or 2004 or 2006 H1 you have no lockers, something that was standard on H2s and on H3s come front and rear!! So many H1 guys 'add' those! None of our hummers come with winches we all have to 'add' those! None of our Hummers come stock with snorkels...we all have to add those! You see my point! We all mod our hummers!
Also every model has it's advantages and disadvantages! There are many a trail that H1s are just plain to wide for and thus can't fit! Win for H3! There are many a trail that requires amazing departure angles...Win H2! There are many a trail with crazy sideslope or deep ruts...win H1!
So you see, we all have our strong points! And we all mod our Hummers...just depends how far you want to go!!!
- NorthBayH1
[quote name='Polar Bear' date='25 March 2010 - 02:14 PM' timestamp='1269526448' post='15157']
Sorry I have to Edit this read carefully
Edit: H1's make the trail I have run over many 50 foot pines in 4low they plow over anything I've seen very few H2's and H3's that can do that less even willing to try Win H1
Edit: H1's have the same angle minus 2 degrees not that big a difference the h1 approach angles shatter the h2's Win H1
link as proof http://www.off-road.com/trucks4x4/artic ... ?id=376150
No Edit : Very True
No Edit : Very True
come on ,keep on posting you guys ..I LOVE THIS ONE <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
i will keep the score <img src='http://www.canadianhummerclub.com/forum ... lleyes.gif' class='bbc_emoticon' alt=':rolleyes:' />
HUMMER H1.......5
hummer h2.......1/2
<img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
HUMMER H1.......5
hummer h2.......1/2
- dbot
Comparison.....
Lets see...
It all depends if you are in the drivers seat or passenger seat. But some general observations.
H2 is twice as fast as the H1, even going down hill.
The H2 tows loads twice as good as the H1
The H2 uses twice as much fuel as the H1
The H2 holds almost twice as many people as the H1
The H2 has twice as much room in the front passenger seat, especially on the first H1's
The H2 is twice as comfortable as the H1 on the highway
I guess thats why they named it the H2
So what are some other comparisons?
Suspension components on the H1 are twice as heavy as the H2 (they still wear out every 30,000 miles though)
The H1 has ctis - so that you can pump them up before driving after letting the truck sit for a few weeks ... from the comfort of the drivers seat (after they have gone flat from ctis leaks).
You can easily crawl under the H1to see where the oil is leaking from - not so for the H2, at least not for me, theres not enough ground clerance.
The H1 has steel drive line components, the H2 has some aluminum parts
Even 2 jeeps can't pull out a stuck H1 (dunville 2006), Don't know about the H2 in the regard, maybe its the same.
The H1 roofs (on the non soft top versions) rust at the seams, whereas the H2 just rusts everywhere
The H1 often gets a thumb, whereas the H2 often gets a finger.
You can look down from the H2 seats and see the H1 below when both are stopped at a stoplight
The h2 was so popular that they made then in two different countries and sold 100,00's of thousands. The H1 is made in onc factory and they sold around 10,000.
You can get an H1 to use for free by signing up with the US army - not so for the H2.
And finally, you can see sam's truck from the space station with all its chrome, You can't see my green H1 from 20 ft away in the bush.
FYI - I have both H1 and H2....
Lets see...
[quote name='dbot' date='25 March 2010 - 05:16 PM' timestamp='1269555380' post='15183']
Comparison.....
Lets see...
Comparison.....
Lets see...
