Need Front Rubber Boot For Axel
What do you need for your Truck or What are you hunting down?
Re: Need Front Rubber Boot For Axel
[quote name='delta1' date='09 May 2010 - 05:32 PM' timestamp='1273440725' post='16661']
I need a H1 rubber boot for the driver side front axle. This is the boot that is attached to the axle next to the front tire and covers the cv joint.
Regards Tim
I have a boot kit pt no. 57k0275. let me know if this is the boot you need
[quote name='delta1' date='11 May 2010 - 10:23 AM' timestamp='1273587817' post='16738']
Roy:
It is the outer CV-Boot kit for the 1993 h1 Hummer and the correct part number from Hummer seems to be #5705606
my kit is for a 99, may be different...
