QUEBEC CHAPTER WINTER MUD RUN!
casey930
Re: QUEBEC CHAPTER WINTER MUD RUN!
Post by casey930 »
[quote name='Polar Bear' timestamp='1291079642' post='23261']
The Address for Next Saturday is
1775 Grimshaw Road
Franklin Center
Quebec
J0S 1E0
I will have a CHC sign on my gate and you will see the Hummers!!!
I might be able to make it, but I will have to be a spectator. My 35" mtz suck on snow & ice, so I was forced to buy a set of goodyear wranglers.
Archngel
Post by Archngel »
Well Im going in with my stock 33.
I postpone my winter tire for the following monday because my winter geolander in mud and stuff,not too good.
They are great on ice good on packed snow, medium in loose snow.
So I kept stock for that event. If I go with stock you can surelly go with your wrangler.
Worst that can happen i swe will have to be winched out. . <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
Neither one of you 'have' to be spectators!! While I do have some really challenging stuff I also have bypasses!!! But if you feel more comfortable on the sidelines then that is OK too...but I doubt you'll be there long!!!
See You There!!
Rhino's winchless and demanding his standard spa day ( Oil Change so still iffy ) add to Kevin being back to work so we'd arrive late . But WE'll see.
Archngel
Post by Archngel »
[quote name='Polar Bear' timestamp='1291254775' post='23324']
See You There!!
Not planning to be spectator,but i want plenty of pictures so you better be equiped to record this event. need pictures for monthly race <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' />
Just remember you have to clean all that mud off the truck after it is frozen!! <img src='http://www.canadianhummerclub.com/forum ... ngHead.gif' class='bbc_emoticon' alt=':banghead:' />
Do not think I will make it,will see closer to date.Truck going in for a major change up. <img src='http://www.canadianhummerclub.com/forum ... /crazy.gif' class='bbc_emoticon' alt=':crazy:' /> <img src='http://www.canadianhummerclub.com/forum ... /crazy.gif' class='bbc_emoticon' alt=':crazy:' />
[quote name='Roy' timestamp='1291293621' post='23348']
Major changes??? Like 42s and a Duramax and Some Lockers???
I wanna Know!!!
citiboy
Post by citiboy »
I'm not sure yet if i go at this moment <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' />. I'll let you guys know by next week <img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' />.
<div> </div>
[quote name='Polar Bear' timestamp='1291295892' post='23349']
I wanna Know!!!
If I tell you,I'll have to KILL YOU!! <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
Don't worry I have spies!!!
TC what is Roy doing to his H1???
