It is possible to have both at the same time, but a quick way to know you have an adventure package or not is...do you have lockers??? If you don't then you have a simple luxury package. If you do then you may have an adventure package with the luxury package add-on.
Hope this helps,
Adventure or luxury?
Re: Adventure or luxury?
- Archngel
in any trim , the adventure package will come with the trail tire LT285/75R16 alluminium mags painted or not, the luxury comes with 16 265/75R16 or 18inches chrome rim and base trim with 265/75-R16 on regular mag
Depending of the model yrs, 06 - 07 no electric seat, 08-09 driver electric seat adventure. Luxury had 2 electric front seats in leather(could not get cloth interior in luxury) alpha late 09-and 2010 you could get the cloth interior. Locker front and rear in 09-10 for adventure, only rear locker on adventure before 06-08, locker on top center console just under the vents are represented by axle diagram with an X on the rear axle, and an X on front axle if you have the capability, the traction control button move by the 12volt plus if you have front ans rear locker in 09 and up.
For sure we can detail many more different options to pin point which trip you have, but those are the main ones tire size and if you have the axle diagram on the right side of the button bar you have locker and by that fact adventure package.
