G'Day my Brothers & Sisters....
Looking at installing dual front shocks on my baby this spring and was looking for input from anyone that has already done so on their rig and where they got the parts from.... been searching on the net and haven't had alot of success and I really wanted to do it myself if possible...
Any input would be awesome!
H2 Dual Front Shocks
- Khamul
- Khamul
Re: H2 Dual Front Shocks
Anyone out there do this?? Anyone???
- normsadler
Nick had dual shocks on his lifted H2, looked awesome! Try contacting nbozzo. Oh, also found this tread
Lifting my 2006 Hummer
Norm & Sue
2010 White H3T (sold)
- Khamul
You don't know where he got the kit from do you?
- JL
Hmmmmm so I was searching the interweb and found that Cognito has a dual shock kit, but list 2003-2007 as the years that fit... Don't know enough about the H2s to know if it's good for the 08 as well but I think chances are good it might?? Maybe worth looking into this Cognito unit at any rate...
- Road Warrior
On my 08 I had Dual shocks installed as part of my Suspension lift from CST and they replaced the upper A arms as well.
The Part numbers were
CSS-C4-4 - DUAL SHOCK UPPER ARM W/ UNIBALLS but they changed for the Pro Joint that has a bolt on ball joint better for the weather here as it is a sealed joint unlike the uniball style
CSS-C5-2 - DUAL SHOCK HOOP
http://www.cstsuspension.com/products/s ... ductID/122
My 05 SUT came with everything installed from Fabtech. I don't know if they are sold separately.
- Khamul
I saw a kit somewhere that didn't involve replacing the upper control arm.... I wish I could remember where I saw it..
- Road Warrior
Khamul,
I remembered seeing brackets that clamp on the upper control arm by Fabtech, but don't know if they are still available as their site shows replacing the arms now but still has Installation instuctions on the site.
http://www.fabtechmotorsports.com/pdfs/ ... 57000i.pdf
My link
Hope that helps
My link
Hope that helps
