Ride Height Difference between the Coil Spring and the Air Spring Model
WIBS
Post by WIBS »
Hi, does anyone know if there is a difference in height between the Air Spring model and the Coil Spring model for the H2 ?
Thank you
normsadler
Re: Ride Height Difference between the Coil Spring and the Air Spring Model
Post by normsadler »
I think the normal ride height is the same, but with air you can boost it up a couple of inches... unless your compressor is broke, lines are damaged or the bags are leaking, then your just saggy back there.
Norm & Sue
2010 White H3T (sold)
maybe Kevin can help on this one.. i think there are some different factors...my H2 has springs...but we could always measure it beside one with an air compressor like John's or Norms..
Thanks John, nice find....
normsadler
[quote name='dwaxman1' timestamp='1295958839' post='24578']
No Derek, mine is a budget H2 with coil springs (like yours), not a fancy air bag equiped one like John or Kev.
Norm & Sue
