Window Motor Repair Kits Preorder
doberer
Post by doberer »
Just finishing up the instruction packet and I am opening up the ability to pre-order the window regulator kits. ETA is about 2 weeks to receive the parts and make all the kits. Left hand and Right hand kits are available. I decided to offer a "kit" because the new parts are re-engineered to avoid a common issue with the dry cable and low torque motor. This new kit is greased and has a higher torque motor to make the window ride smoother.
If you are asking yourself why would you need something like this...go and price out what the AMG replacement assemblies cost and then when you wake back up from passing out you will understand. As of today they are approximately $500 LH and $900 RH each.
A Hummer Parts Guy Exclusive solution to a common issue for worn out window motors. This kit includes everything you need to repair your existing window motor assembly. The repair only takes approximately 45 minutes and uses your existing wire harness (plug and play) and metal cable guide.
I will also rebuild your existing assembly and perform the upgrade if you send the old assembly to me. FREE
Kit Includes:
* Detailed instructions with photos
* New window motor and gear
* New motor cable
* New mounting brackets
* Misc Hardware
Introductory price of $150ea + shipping (USPS).
Part Numbers:
6002871KIT > REGULATOR KIT, WINDOW, POWER (RH)
http://www.hummerpartsguy.com/product.asp?itemid=14676
6002870KIT > REGULATOR KIT, WINDOW, POWER (LH)
http://www.hummerpartsguy.com/product.asp?itemid=14675
Thank you. Please let me know if you have any questions.
David Oberer
1996 AM General 6.5L NA
Hummer Parts Guy - Canadian Hummer Club Sponsor
Blackberry: 920-216-6898
Website: www.HummerPartsGuy.com
Re: Window Motor Repair Kits Preorder
[quote name='Hummer Parts Guy' date='12 September 2010 - 05:17 PM' timestamp='1284329826' post='20874']
Kit Includes:
* New motor cable
* Misc Hardware
Part Numbers:
David Oberer
sounds great to me .....I'm in for my 2003 H1 driver side !!!
need a passenger side one....
looking forward to getting this Dave... my rear passenger is done in for sure....
Fusioncruiser
Post by Fusioncruiser »
[quote name='Hummer Parts Guy' timestamp='1284329826' post='20874']
Dave, you once again are my hero!!! First my starter that you saved my bacon on and now my window! You are the best!
I'm going online to order right now.
<img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Thanks,
Shawn Morrow
1998 H1 Wagon
2007 Toyota FJ Cruiser
[url="http:/www.compu-knights.com"]Compu-Knights[/url]
How are these doing... any feedback on anyone that got one??
Tom
Post by Tom »
[quote name='dwaxman1' timestamp='1295881936' post='24498']
Just buy one already! Stop asking for so much feedback!
not nice Tom... nice nice...Image
If you want to see what they look like, I have 8 in stock!!
[quote name='Tom' timestamp='1296520996' post='24809']
<img src='http://www.canadianhummerclub.com/forum ... feSpit.gif' class='bbc_emoticon' alt=':coffeespit:' /> <img src='http://www.canadianhummerclub.com/forum ... feSpit.gif' class='bbc_emoticon' alt=':coffeespit:' /> good one <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
