Has anyone had any luck in painting their interior trim pieces, like the dog house, etc?? mine are all gray but stained, apparently the previous owner had a bit of an issue with spilling things....
wondering if you did have luck, how well did it go and what did you use?? I would like to turn all the gray to black on the inside of my wagon...
Painting interior Trim pieces
- doberer
Re: Painting interior Trim pieces
Tan Paint and Gray paint is made by Eastwood. Same paint spec as original. I will post the paint codes later tonight. The majority of trim now sold from AMG is black and it is paint to match.
- jnorth
[quote name='dwaxman1' timestamp='1300540572' post='25984']
Yep, just got done with my project. very impressed with the product. Duplicolor vinyl and fabric paint. It does not rub off or scratch! I turned my wagon from tan to grey and black.
looks great...can you post a photo of what the paint can looks like if you still have them??
- jnorth
[quote name='dwaxman1' timestamp='1300759708' post='26130']
sure, might be a day or two. Canadian tire carries it in the automotive paint section.
no worries then, i will check it out... did you prime it at all??
- jnorth
[quote name='dwaxman1' timestamp='1300759898' post='26133']
no need to prime. you must prep very well though as in any paint project. clean thoroughly with something that will not leave any residue. ie; an aerosol glass cleaner with alcohol in it.
excellent.... and the dupli-color is a spray I assume??
- jnorth
[quote name='dwaxman1' timestamp='1300760273' post='26136']
yes
yes
