After a few hours offroad today, I am now unable to put my H2 back in 4 high. All of the switches lights are off. When I try to switch it, the light flashes for a few seconds then turns off again. The truck feels like it's still in 4 low, and is having some trouble shifting gears.
Any thoughts?
Stuck in 4wd low?
Re: Stuck in 4wd low?
silly question but you were in neutral when you tried to shift back to 4hi
yes what Derek said ! Also try reversing 30 to 50 feet also . Do it a couple of times . What year is your H-2 ? The H-2 owners on here might have had something similar . Knowing what year of vehicle is a great help . Different years had different bugs in them . Hope all goes well .
Last edited by johnnyspikesH3 on Sun Jul 24, 2011 6:35 am, edited 1 time in total.
- Deacon444
[quote name='johnnyspikesH3' timestamp='1311492421' post='29050']
Yes, it was in neutral when I tried switching it back. It is a 2003
- brianwidahl
i have a 03 h2 and its done that to me to.
like said i just moved forwards and backwards and kept trying.
mine works fine now but it takes a good 20 seconds to change over
my 05 takes a few seconds, not a ton but it will switch..can you engage your rear locker?
- Deacon444
[quote name='brianwidahl' timestamp='1311526515' post='29053']
Tried this with absolutely no luck
[quote name='dwaxman1' timestamp='1311528386' post='29056']
Haven't attempted it with fear of causing any more problems. Also did a scan and it's showing a P1875 code. Looks like it may be going into the dealership.
good luck... keep us posted, I hope you didn't damage your transfer case...
- Deacon444
Just got it back from the shop. Broke a wire in the 4wd circuit offroading. $90 repair.
[quote name='Deacon444' timestamp='1311608565' post='29085']
Good, sounds like an easy fix.. lucky!!
