H2 Tire Carrier Hinge Bracket
SELL Spare parts, OEM, After Market, what ever that is Hummer related and for your Trucks
Hesh
Post by Hesh »
Well, in trying to fix the hinge & clean/grease it, we attempted to remove it, and it busted. If anyone has a spare one lying around, let me know.
The style of carrier hinge I need, is shown below. I JUST need the hinge section. If anyone has a part number for the one Im looking for, that'd help too.
this is the style I *DO* have, and I need the hinge section
As far as I know there were only two OEM styles that these trucks came with. The one I need parts from is pictured above.
Re: H2 Tire Carrier Hinge Bracket
which part?? the latch on left or hinge on right?
Hesh
Post by Hesh »
The Hinge part.
I have the other style.. maybe check with Darcy aka HeavyDe.. I know he has a few tire carriers kicking around..I.will look in documents I have for a part number...
GM part number 15267627 Hinge lower hope this helps.....
I believe this is it from gmpartsdirect.com
ImageGM PART # 15267627
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
ImageList Price:$340.22Price:$204.74You Save:$135.48 (40%)DESCRIPTION: HINGE
Page 1: 1-1 of 1 items
NOTE: GMPartsDirect.com carries 380,000 GM parts. Due to the number of parts available, the part you are searching for may not appear in these results. Please use our Customer Service page if you need help locating a GM part. Can’t find a part?^ Back to Top ^
but double check first......
Hesh
Post by Hesh »
Sadly, as seen in the link's image, that is the part number for the wrong style of hinge. Thanks though.
http://parts.nalleygmc.com/showAssembly ... bly=392627
sorry bro... that is the number that I took for my 05 parts manual...I will do a bit more digging...maybe talk to tanky.. he has the same model installed on his truck that you are looking for
Hesh
Post by Hesh »
Just for gits and shiggles, what would you want for other other style carrier? I'd rather try and find a toss-away hinge as it'd be my cheapest route, but throw me a price anyways lol
Road Warrior
Post by Road Warrior »
That Carrier Model was made by SMA and it was an aftermarket design made for the 03 and 04 model. you could remove the Tow Loops and bolt this one on with the tow loops fitting on top.
I have the same one on my 05 SUT mounted on a R/A rear bumper.
in 2005 Hummer came out with the Factory one that had the tow loops integral as part of each piece. the both mount the same but the SMA model uses the factory topw loops that came with the 2003 and 2004 nodel when the spare tire was mounted inside.
2005 the spare was moved outside, thus the Factory Carrier with Tow loops mounts built in.
I don't know where to find parts for this one, and I just used a 1/2" Locking reciever pin for mine instead of trying to find the Factory Pull pin and it prevents anyone being able to pull the pin only to find out when you drive away that your tire carrier is swinging and banging around unlatched by someone that thinks it was a funny thing to do when it is Not !!
Hope you find the Hinge bracket that you need, if I see any information for replacement parts I will repost.
You may have to try Kijijji or something to find another one and then have spare parts <img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' />
