Removing ABS & TT4
3dinnovations
Re: Removing ABS & TT4
Post by 3dinnovations »
[quote name='humybby' timestamp='1316546453' post='30513']
I need to ask, why would you remove the TT4 system?
I have an '01 with ABS, TT4 and I've installed Eatons. I really feel I have the best options available for any conditions. I can BTM, I can use TT4 or I can lock up. I feel there's a condition for each tool I have available off road.
If your TT4 light is coming on I suggest fixing the problem, it's usually not that difficult. Almost always it's a sensor that's backed off from the tone ring. It just needs a business card between the tone ring and the sensor, then gently tap the sensor so the business card is tight. Remove card.
Are you aware of the 'jumping pins 4 and 15 trick?' It flashes out a code that will help you diagnose the problem very quickly. It's called the Blink Code Procedure. It'll tell you which sensor needs adjusting.
If you Google 'TT4 Blink Code Procedure' you'll find what you need.
Greg
Thanks for your reply Greg. I understand your point on keeping both. The only reason I wish to remove it is because of the lights coming on intermittently. But lately they've been cooperating! I used to get all kinds of codes. The first code was the (2-6: Shuttle Valve switch failure). Then I got another one, then another one! All of them were different which made me conclude that I must have a wire shorting out somewhere. I reset the code and it usually does the trick <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
If the lights stop coming on, I will try to keep both systems (ARB & TT4) and see.
Cheers,
Scott
Ride Hard!
humybby
Post by humybby »
[quote name='3Dinnovations' timestamp='1316551299' post='30516']
Cheers,
Scott
Scott,
Next time you're poking around - check your ground posts. When you get wierd electrical things happening that's the first place to check.
IIRC there's one down by the fuse box and another just in front of the driver in the engine bay. Juast make sure they're clean and tight.
Anyway, glad to hear it's better - electrical things are like magic to me. i just don't understand them....
Greg
AKA - Hollywood
2001 HMCS - knows how to get to Moab all by itself!
3dinnovations
[quote name='humybby' timestamp='1316556913' post='30520']
Scott,
Greg
Thanks Greg! I will check the grounds ... makes a lot of sense <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Ride Hard!
