Beautiful H1 forsale in Alberta..very clean
03H2
Post by 03H2 »
Found this today while surfing around..looks like someone looks after their ride
http://medicinehat.kijiji.ca/c-cars-veh ... Z317632536
[center]o [O] I I I I I I I [O] o[/center]
[center]HUMMER: Curing those "Almost got there" Blues....[/center]
tomserroul
Re: Beautiful H1 forsale in Alberta..very clean
Post by tomserroul »
[quote name='03H2' timestamp='1317344824' post='30809']
I just took this Hummer in for a inspection and this is what it came out with
-No cruise control
-No windshield washer
-Fuel gauge not working correctly
-Front markers and rear brake lights not working
-steering wheel not straight
-LR Hub seal leaking
-RF rear upperarm loose
-idler arm, Pitman arm and left tie rod have play
-Front and rear pads and rotors warn down
-Transmission pan leak
-Exhaust leak at left manifold
Hesh
Post by Hesh »
I havent seen this, but FWIW:
Marker and brake lights and cruise control are probably just a bad/blown fuse - easy fix
Steering wheel - meh
Hub seals always go, nothing of any large expense or big deal there. Relatively easy fix.
I think the main things that would concern me would be the Pan leak, and the guage not working properly, though it may be a decent amount (not crazy $$ but a decent chunk) to replace all the worn components (ie: pitman, idler, etc).
I'd be more concerned with A) Does this have the heavy block/warranty replacement block B ) Changing out that K&N Filter first off the hop (the K&N's for these trucks have been proven to do more bad than good) C) Why it has a new stack & windshield (possible collision?)
-No cruise control
tomserroul
They bought it in 2005 from nova scocia at 100,000 km. They replaced the windshield because it has a lot of pitting and chips in it they said. Carfax shows a clean record. They don't know if the warranty block was put in. Do you know a way I can find out and see?
tomserroul
Oh yeah and he said he out a new starter in because he was wireing the lights in and arced out the starter last month.
Archngel
Post by Archngel »
you would need the VIN in order to see what kind of engine was in it originally
Hesh
Post by Hesh »
The original engine bears little impact on what motor you'd want in there now. There are ways to inspect the motor to find out if the current motor (assuming/hoping it's been replaced) is the upgraded heavy block or the defective #8 block.
Familiarize yourself with these two articles, and there is a wealth of information in the adjacent site's articles.
Defective block identification and information - http://www.flashoffroad.com/Diesel/No8C ... dBlock.htm
Buying a Used Truck Info - http://www.flashoffroad.com/features/bu ... gUsed.html
tomserroul
The vin has a Z in it. Im not near the truck so I can't check the block. Its not cracked yet atleast since I did the coolant pressure test by starting it when it was cold. It's 12 years old now with 147,00 so maybe it was changed under warranty hopefully.
thedub
Post by thedub »
from what I'm reading here.... it sounds like more trouble than its worth.
[center]Yellow H2
Mississauga, Ontario.
(try that in your prius)
Hesh
Post by Hesh »
Not a risk I would go into blindly, especially with motor replacements costing upwards of 15K (parts and labor).
I absolutely did not want to take this risk, hence my 2001.
