Hi H3 Owners.
Just been across this on Ebay H3 Rocker Protector set Its in the US but for some it doesnt appear to be a problem to go get them. Really good price at 299. at plaza they run around 900$ Might be interesting for some.
Rocker Protector H3
- Archngel
Rocker Protector H3
- lasallejai
Re: Rocker Protector H3
The shipping cost will kill the deal for sure. I used an Indiana zip code to check and it is already $90US so I guess for Canada it would be at least double, not to mention the Canadian Customs will likely rape you with the 13% HST. No import tax because they are made in Canada. Still a fairly good deal if any one can a pair for about $600CAD.
Or I could make a set that would be way stronger and even integrate a side step! And at least mine would be indestructible!
So who needs a set, my welder needs a workout!!!
I'm impressed alone they are made in Canada ! So P.B IF WE WONT . WE CAN START PLACING ORDERS ? Your good to go to start STOKING THE FIRE ? <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Last edited by johnnyspikesH3 on Fri Oct 28, 2011 1:27 pm, edited 1 time in total.
[quote name='lasallejai' timestamp='1319808088' post='31877']
Lol ( WILL RAPE YOU ) . Assume the position we will be taking your wallet. Good one <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Last edited by johnnyspikesH3 on Fri Oct 28, 2011 1:18 pm, edited 1 time in total.
If Kevin makes you something, it will be ROCK SOLID!!!
