Heated Windshield Washer Fluid
- Gadgets
I have a button for Heated Windshield washer fluid in my 2007 H2. It doesn't seem to toggle, or click in and out like a on/off push button normally does. Also, it looks like there should be a light on it. The manual sucks at saying much about it. Can anyone tell me what I should be seeing when trying this??
<p class="bbc_center">
- JL
Re: Heated Windshield Washer Fluid
I seem to remember a warranty fiasco where GM was paying owners to actually remove the heaters from their vehicles all together... Not sure how long you've had the Big H but there is a chance it's been removed entirely!
Other than that can't really help <img src='http://www.canadianhummerclub.com/forum ... #>/sad.gif' class='bbc_emoticon' alt=':(' /> Wish I knew more!!!
- Gadgets
[quote name='JL' timestamp='1322006544' post='32979']
oh really, well that might explain the lack of function. I should have checked on this in the summer, I could have traced things out to see if it came to an end!
i've only had it since the beginning of July this year.
thanks for the info
thanks for the info
- Gadgets
Just did a quick Google search, and indeed you are correct. The H2 was involved in that recall. It was a recall of 1.5 million. This due to like 5 fires caused by this same system. If you acted on the recall a dealer would remove the module, and GM sent you $100 for the loss of the feature. Maybe I'll design my own. <img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' />
- boarral
[quote name='Polar Bear' timestamp='1322062729' post='32996']
If you really want the feature, here is one you could use;
http://www.windshieldwiperheaters.com/
I think Canadian Tire sells these, or one that's similar. And they're less than $100 if memory serves correctly. It's tempting! I've also been eying up heated wiper blades. And since I just broke one this past weekend...
(Though it works better now that the plastic backing broke than when it was intact!)
1993 Mitsubishi 3000GT VR4
2005 Ford Excursion Eddie Bauer
2005 Hummer H2 SUT
2005 Hummer H2 SUT
Actually the most cost effective and efficient heated washer fluid you could have would be to take a piece of bendable copper or stainless steel tubing and wrap it around your driver's side exhaust manifold. Just make sure that the ends where the rubber connects to it is far from the exhaust. This will work very well and is a completely manual system. I have seen it on a couple of trucks...just haven't got around to trying it on my own yet!
I am not a big fan of heated wiper blades just because of the electrical that has to move with the wiper blade.
- boarral
[quote name='Polar Bear' timestamp='1322064188' post='32998']
True. Though the brand I was looking at had a pretty impressive warranty. That was a couple years ago though. A lot can change...
2005 Hummer H2 SUT
2005 Hummer H2 SUT
- JL
Even the Canadian Tire units underwent a recall a few years back!! No idea if they're more reliable now...
- Indy
Wouldn't this make the water really hot, especially if not in use, since there will always be water trapped in the lines. Also, spraying hot water on an ice cold windshield might not be the best idea...but then again I might be wrong. Just a thought. For me, antifreeze Windshield washer fluid is the best and safest way to go and a cover for the windshield while it is parked outside to prevent it from freezing.Actually the most cost effective and efficient heated washer fluid you could have would be to take a piece of bendable copper or stainless steel tubing and wrap it around your driver's side exhaust manifold.
Ferrari Mondial 3.2 Cabriolet
Jeep Grand Cherokee 5.7 Hemi
99 HUMMER H1 HMCS / bright white / P400 6.5TD / heavily modded - sold
VIPER RT10 GenII / silver - graphite stripes - sold
FJ Cruiser / sun fusion yellow / "C" package- sold
HUMMER H2 / yellow / Adv. package / 4" lift / 37" STT - sold
Plymouth P R O W L E R / red - sold
Corvette C5 / Millennium Yellow / 6M - sold
Corvette C5 / Nassau Blue / 6M - sold
J E E P ZJ / 7" lift / white / 35" Cooper STT - sold
J E E P TJ / 7" lift /chillipepper red / 37" MTR - sold
Mustang GT 4.6 / black / 5M - sold
