Rock Sliders and Running Board
- SwaggBoss
I am planning on lifting my H3. I would like to know if I could install running board with the rock slider on it? I need running board or steps because I have some friends that cannot reach up if I lift my H3. Please leave any links if you guys found a rock slider with steps/running board for HUMMER H3. Thanks
- Archngel
Re: Rock Sliders and Running Board
There is the rock panel protector + the mini step from GM for the H3
In my case I took the brackets from a mini step set and put them on my long running board and installed it on the rock panel protector. whe ni go off road i remove 3 nuts remove the running board and go.
[quote name='SwaggBoss' timestamp='1325908223' post='34250']
Just put in your rig info at the top ! Enjoy www.n-fab.com
Last edited by johnnyspikesH3 on Sat Jan 07, 2012 3:52 am, edited 1 time in total.
- SwaggBoss
[quote name='Archngel' timestamp='1325909232' post='34252']
Can I please see some picture?
I would suggest Ridge Demon rock sliders, way better than any other product out there and they protrude about 2" out from the body, that means rocks stay that much further away from your H3s door! And you can install the removable steps. Check out the following links;
http://www.youtube.com/watch?v=QaeDvrxn ... ature=plcp
http://www.youtube.com/watch?v=CVbv9WReHx4
Enjoy!
Enjoy!
- SwaggBoss
[quote name='Polar Bear' timestamp='1325935576' post='34268']
http://www.youtube.c...=7&feature=plcp
http://www.youtube.c...h?v=CVbv9WReHx4
Enjoy!
AWESOME BUDDY!
THANKS A LOT!
Enjoy!
AWESOME BUDDY!
- Allenx71
Enjoy!
i went to their website but i cant even order from them cause it keeps telling me the links expired. any idea on where i can get them?
Enjoy!
