Picking up tomorrow ! Need advice
Hey Brothers and sisters . Need advice .. Picking up HI-LIFT JACK 4 years old never used $100 dollars . Also comes with a few goodies . Question best cheap roof rail mount for my H3 . I kinda like the YAKIMA UNVERSAL MIGHTY MOUNTS . Any other suggestions or advice . Best bang for the buck . I like the Yakima cause of the fast access . Thanks
- SADA
Re: Picking up tomorrow ! Need advice
[quote name='johnnyspikesH3' timestamp='1326507517' post='34434']
Hi I bought mine at Schlueter Chevrolet in Waterloo original Hummer one, looks good and it's made for H3. You can check it out on they website.
- Hesh
Dont bother mounting it if you dont buy the neoprene cover, and a rebuild kit. The cover will keep most junk out of the contraption and prevent corrosion/rust/buildup which will cause it to seize, and the rebuild kit will replace/fix the parts that do sieze/rust/fail. Otherwise it is just for looks, and prone to theft sadly.
I have had mine mounted on my H2 for years now, never had an issues and I coat it with spray lube and it works great...I might be one of the lucky ones...only used it three times...
anyways post a picture Johnny boy!
- shattuck
mine is also H2 faced some problems but they are all minor issues
