check out this link if any of you haven't seen it before.
It's the 2010 H3 Alpha.
My link
The thing was hydrolocked after.
something wrong with the design of the car or the driver?
- baowu2
Re: something wrong with the design of the car or the driver?
I think it was just bad luck . Yes maybe he could of took it a bit slower . He did DIP in the ground mid way . Underwater surprise ! Got that big wave , which i guess got into his intake . Also Knocked the crap out of his front plate . His angle of approach seemed solid . Explain this ? I seen on another vid by this nut bar . He has no snorkel at all . How the heck is this happening ? http://www.youtube.com/watch?v=XD1wimVl ... detailpage
Last edited by johnnyspikesH3 on Mon Jan 23, 2012 10:53 pm, edited 1 time in total.
[quote name='johnnyspikesH3' timestamp='1327363998' post='34625']
Are you sure he has no snorkel??? That would definitely not be possible without one!
[quote name='Polar Bear' timestamp='1327404367' post='34643']
OK 100% no ! Other videos of his H3 there is no snorkel . Maybe at the time of this there is but you can't see diddly . It's crazy i know Kev . <img src='http://www.canadianhummerclub.com/forum ... /crazy.gif' class='bbc_emoticon' alt=':crazy:' />
Last edited by johnnyspikesH3 on Tue Jan 24, 2012 7:04 am, edited 1 time in total.
holy crap!
- Archngel
On the first video, of the White H stalling in water,, that is just plain stupid.
Especially for an 09 or 10.
I noticed on my 06 that the corner bumper were see through ( open )you could see the tire directly. The inner fender liner didnt reach to include the opening of the corner bumper. so in short the breather box was kind of enclosed in the inner fender and not much was getting in there unless you were just sitting in water deep enough to get the fender in the water.
When i changed for my 09 and then my 2010, the corner bumper wasn't open anymore, instead i twas leading to the inner fender, directly where the breather tube is. the liner of the inner fender is now enclosing the corner bumper so if you rush fast enough to get water above the corner bumper and water gets into that opening the water rides in your inner fender and the risk of being aspirated is +++ .
I don't know about the 07 or 08, but I found that this mod was kind of stupid. At first I was thinking that for the Alpha's they needed more air and that was the reason for this channeling, but my 09 was an I5 and the inner fender liner was set up the same so that was the end of that theory.
in any case, I dont really like swimming with the H, especially when I dont know the water, what kind of bottom, how deep, and as anybody been through before. if they lost a Caterpillar D7 in there, for sure i wont try it, hahahaha
For the other video,, if he doesnt have a snorkel, its miraculous, as water appears to be at the fender flare so well above the corner bumper. so if an 06 he may be lucky and water doesnt get into the inner fender, but if its a later model,, water is in there,, so he needs a snorkel for sure.
