Hey Guys,
Just wondering what you keep as spares aroud the house for your H1?
Seems as though parts aren't the easiest to come by in short order unless you live in or at least close to a major city. If you are going wheeling and you are the only H1 in the group what kind of spares do you take with you? I know this is a hard question as the sky is the limit, but are there some typical parts you keep on hand on a just in case basis?
Thanks.
Spares - What do you keep in the home garage?
- nitrous
Re: Spares - What do you keep in the home garage?
You should always carry a spare when off roading. When daily driving, a good same size spare at home is not a bad idea. CAA is needed to get you back home or have the better half drive you out a spare, jack and t wrench. Provided they can load that tire themselves and find your tools. <img src='http://www.canadianhummerclub.com/forum ... #>/dry.gif' class='bbc_emoticon' alt='<_<' /> <img src='http://www.canadianhummerclub.com/forum ... nfused.gif' class='bbc_emoticon' alt='
' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
The expense of having a spare will at least keep you wheeling instead of parking for a week or more. <img src='http://www.canadianhummerclub.com/forum ... um__no.gif' class='bbc_emoticon' alt=':umno:' />
I carry 2 spares per vehicle when off roading.You never know!! I have destroyed 2 tires on two different trips.At least I could drive home again.
At my shop, I carry 3 used sets and a new set of tires, 3 complete sets of rims.CTIS fittings..............
And very soon, a hummer recovery roll off. <img src='http://www.canadianhummerclub.com/forum ... ngHead.gif' class='bbc_emoticon' alt=':banghead:' />
- 3dinnovations
I have enough tools in my H1 wagon to disassemble and reassemble anywhere!
Spare parts:
- Spare Tire
- Pitman arm
- Spare ECM
- Fuses
- nuts/bolts
I have most of the tools with me all the time and also carry all the necessary recovery gear (2 winches).
And First Aid kit is also important.
I do extreme offroading so a daily driver wouldn't need all of this.
Spare parts:
- Spare Tire
- Pitman arm
- Spare ECM
- Fuses
- nuts/bolts
Ride Hard!
- Hesh
You should post what year H1 you have, this may help with more custom tailored suggestions for spares (some vehicles had components that were more prone than other model years, etc).
Im developing my list, as I have a big trip coming up to Moab this fall, so my Garage spares, will also become my trail/trailer spares but it will be as follows:
Spare PMD (in my shop at ALL TIMES)
Stanadyne Diesel Additive (in my shop & truck at ALL TIMES)
Balljoints
Fuel Pump
Fuses (assorted)
Inner and Outer Geared Hub Seals - multiples & geared hub seal-driving kit
Bluehummer Limp-Home Kit
Bluehummer brake-line repair kit
Spare halfshaft bolts and nordlocks
Pair of Pads & Rotors
Tire puncture & seal repair kit
6L Lucas Hub Fluid
12L of Rotella Syn Oil
12L of Dexron III
6L of Redline Dex III Synthetic ATF (for the TC)
2 bottles of Ford additive (friction modifier) for the Auburn in the rear
8L of Gear Oil
Coolant
2 bottles of Redline water-wetter
Brake & Steering fluid
Stanadyne Fuel Additive
For trail spares I will have:
2 Idler Arms with Mounting Hardware
2 Pitman Arms
Spacers
2 Upper Ball Joints
2 Lower Ball Joints
Complete Front Tie Rod Assembly
Diesel Motor Mount
Spare Castle Nuts
Spare Ball Joint Mounting Hardware
Spare Steering Gear Mounting Hardware
Spare Pitman Arm Lock Washer & Nut
12 Cotter Pins
Fullsize spare tire.
(atleast, if not more) a rear halfshaft
I will also be packing an Oil & Tranny filter, and Tranny Gasket.
Im sure Im forgetting what else I keep on hand, I'll update as it comes to me.
Balljoints
Fuel Pump
Fuses (assorted)
6L Lucas Hub Fluid
12L of Dexron III
8L of Gear Oil
Coolant
2 Pitman Arms
Spacers
2 Upper Ball Joints
2 Lower Ball Joints
Diesel Motor Mount
Spare Castle Nuts
12 Cotter Pins
- nitrous
Thanks Guys that gives me a pretty good idea.
Fingers crossed I'll be an H1 owner in a couple weeks time.
Just trying to figure out what I might need to stock in the garage and have ready for the trail.
