Here are few picture of the new shows for the H , pictures were taken with Berry once out of shop , if you are wondering abotu the one on top, I moved all my winter to the storage. 4 315/75 16 in the cargo the fifth one didnt fit <img src='http://www.canadianhummerclub.com/forum ... #>/sad.gif' class='bbc_emoticon' alt=':(' /> so i had to put it on the top, I couldnt beleive 4 of them fitted inside.
I think it starts to look like Kev Monster H2, the tires are growling GIVE ME SOMETHING TO SINK MY THEET IN'' GRRrrrrr
Toyo Open Country LT315/75 16
Solid choice, 2 months now and I love them more everyday!
At what tire pressure are you riding them on the road , right now mine are at 35, ride is smooth ( meaning it rides like on a pool table ) and feels higher although the same as my winter yoko 34.9, almost same foot print too yoko 12.6 toyo 12.9
I noticed, the rubbing on the torsion bar and on the frame when on full turn a bit more because of the space between the log on the tire and they are a bit wider than my winter ones (foot print yoko 12.6 toyo 12.9 that is where the rubbing comes from ).
a bit noisier than my winter tire but nothing that the sound of the exhaust or the radio cant muffle, its just a hummmmmmm.
So, so far I'm happy. Wont have the chance to try them in April as Ill be away, but I hope in may if we are invited at Polar Bear Playground or else where we'll see how far they can go. I already know that I can follow anything almost anywhere ( H1 with 18 to 21 inch clearance is hard to beat ) But with smart driving anything is possible.
Looks great ARCH . Sounds like you might have to throw some spacers in there with the rubbing . Ordering my Magnaflow Cat back in 2 weeks . Then found out that Rocky Road does ship to Canada . So i think i am going to go that route on sliders . I wanted to go Ridge D , B-Man has shut it down for a while . When it will be up and going might be over year or so . Anybody know how much the Rocky's weigh <img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt='???' /> They don't look light . To bad Warn does not make any sliders for HUMMER . They look like they be pretty awesome also .
Thx JohnnyspikeH3
I have the magnaflow, nice sound with my 8, found the pipe to be a bit long and they are in the way of the Exit angle.
Other than that,love it.
For the slider by the look of it they would be at least 40 lbs each, my OEM weight about this 40lbs each.
Hey Marc,
The rubbing will be normal...the toyos have large sidebiters and the yokos don't! Mine rub also...no biggie!
