VIBRATION
Re: VIBRATION
I was referring to my truck...not yours...sorry to hear you are feeling that frustrated, do you have runflats?
Sub
Re: VIBRATION
Post by Sub »
[quote name='dwaxman1' timestamp='1303873923' post='27336']
yes i do, - do you think its because of them?
Tom
Re: VIBRATION
Post by Tom »
Take out your runflats. They are probably two piece units and they may be loose. I have been running with no runflats on my 40's for quite some time without a problem.
Re: VIBRATION
I have one piece Runflats in my and they add weight but Phil balanced nice, I have a bit of vibration around 65-70mphs but I don;t put my truck that hard so no big issue.
I would suggest you go back to Phil and let him have a look at it, there isn't anything he can't fix
ride2099
Re: VIBRATION
Post by ride2099 »
I got same vibration problem !! i really thinkg is a bering or shim smewhere i the shaft cause rims problem shaking the steering too but this vibrwtiin is not in steering wheel o i realy thing is loose bering or shim something like that !
HUMMER H1 SUT 1998 6.5TD
priuseater
Re: VIBRATION
Post by priuseater »
Im going to take a guess and say its probably a wheel balancing issue. Give the plastic bead test a try. I wouldnt be too concerned about the CTIS being cloged with the bb's because its fed inside at the rim, and i would highly doubt a bead would find itself in that spot at the same time your airing down. I dont know how the seel rims are setup, but i believe on the aluminum ones the air feed is theaded all the way thru, so you could put a mesh insert or a "air silencer" as they call it in the pneumatic world to pervent beads workin their way up the line if your concerned. Although i dont have any vibration problems at all myself, the bb fix did intrique me, and ill probably take a spin at it when its time to put some new tires on. I have the 1pc runflats on my 2pc 17", and i just bought the replacement hutchison beadlock insert (w/o runflat). Actualy just got them in today <img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' /> they will help cut down on the weight a bit. Last fall when i as changing the hub oil, i couldnt believe how heavy the wheels were; almost 180lbs+ each with the 10 ply toyos. I would be pretty screwed at the side of the road changing a flat by myself.
If a rebalance doesnt do the trick, my only other guess would be a torque converter shutter at the speed right after the t/c locks; which is around 70-75km/h
priuseater
Re: VIBRATION
ride2099
Re: VIBRATION
Post by ride2099 »
I dont think is the ctis cause i run aluminum aftermarket rims with no ctis I go balance my rims in 2 days cant wait !! i dont wantto broke shaft or my engine crank due to the vibration
Sub
Re: VIBRATION
Post by Sub »
good point - sometimes both shafts can get vibration effects, i will chk my shafts tomorrow too,i think is a good idea
ride2099
Re: VIBRATION
Post by ride2099 »
hey guy issues fix !! my rims was totally unbalanced !! the 4 rims need balance and I got my front right tire to change is not round anymore so making my vibration !! so today i order new tire and new rims hahaha
(4) Yokohama geolandar m/t 38x13.50r17
(4) eagle alloy 027 Black 17x9
Cant wait to put on the truck !! I also need to replace (2) Upper ball joint so ball joint and new rims tire its a 3500$ repair hhahahaha
