Need HELP again..My 2008 stalled after started up?
citiboy
Re: Need HELP again..My 2008 stalled after started up?
Post by citiboy »
I have the exact same problems as yours, turned out to be the fuel pump control module...dealer replaced it under warranty...problem went away completely.
Hope this helps!
<div> </div>
