leveling kit installation
trinbal
Post by trinbal »
hey guys what kind of labour is involved in installing a leveling kit for my 2003 h2? Also any recommendations on what make of leveling kit should i buy ?
johnnyspikesH3
Re: leveling kit installation
Post by johnnyspikesH3 »
The kits range from $75 to $300 dollars . With everything,you get what you pay for . The more expensive kits are better made . ( quality of the metal in the torsion keys).Also they will come with shock relocators.There are sponsors on here you can order from . Or you can order online from E-bay ..etc . The kits should allow you to be able to lift the front 1.25 to 3 inches . Remember even after you install the kit. There will still be minor torsion bar adjustments needed to have it level.99% of the time one side will be higher then the other . There is NO magic Wala !! It's leveled perfect . In my H3 i have a kit that included a rear 3/4 inch rear shackle set up . MY FRONT lift is 2.5 INCHS AND I STILL WANTED IT ABIT HIGHER . My front is at 24.25 now . The other guys on here know what i am talking about . Now you can also just crank you torsion bars to lift your rig . I am not up on the exact inches of the H2 ride height in the rear . I attached this link of a guy who lifted his by cranking his torsion bars . http://www.eeaston.com/2006/09/tighteni ... sion-bars/ You will need a alignment after . It also good to drive it for a few days first.Just in case one side settles and you have to adjust it again . Then do the alignment . Again i do not have a H2 and maybe the other H2 guys can way in . I know the factory rake is horrible ..Hope this helps .
Last edited by johnnyspikesH3 on Tue Aug 21, 2012 7:05 am, edited 1 time in total.
In addition Rhino had his superlift leveling kit done by dealer as alignment was due for check so made job way easier than us doing it then getting alignment.
