Hi Guys and Gals,
My H2 has died in the driveway. I checked the battery and it is all good but when I try to turn it over all I get is a click, click, click noise that seems to be coming from the speakers and under the drivers seat... I am at a loss as to what is causing it.
Any ideas please???
(need it fixed ASAP as the dogs are not allowed in the wifes car!!)
truck dead....
- thedub
truck dead....
[center]Yellow H2
Mississauga, Ontario.
(try that in your prius)[/center]
- Autumn Walker
Re: truck dead....
sounds like a bad starter to me.
2007 HUMMER H2
Re: truck dead....
^^^ I agree with with above . Starter !!!
Re: truck dead....
[quote name='martdedub' timestamp='1351954948' post='40783']
Hi Guys and Gals,
Any ideas please???
That no way to talk about the kids! <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
Try putting it into neutral and trying to start. same result?
check battery connections, try a boost, then suspect a starter.
So , time to replace truck with an H1. <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Hi Guys and Gals,
Any ideas please???
- thedub
Re: truck dead....
Ok, Sooooooooooooo my buddy next door had the same problem yesterday as well..... so I checked his battery and it was good... long story short my battery tester is now in the reverend whats him names back yard (at least that the direction I threw it!) across the street.. and I went out and bought a new battery and all is good <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
My doggies are now happy again that we can go out (and yes Roy, they are like my kids..... in fact I like them more <img src='http://www.canadianhummerclub.com/forum ... >/wink.gif' class='bbc_emoticon' alt=';)' />
Cheers folks <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
[center]Yellow H2
- 1650shawn
Re: truck dead....
[quote name='martdedub' timestamp='1352048056' post='40801']so I checked his battery and it was good... long story short my battery tester is now in the reverend whats him names back yard (at least that the direction I threw it!)[/quote]
proper voltage does not mean your battery is good,it needs to be cheched for cranking amps.Best way I know is to hook up to an alternate battery source with booster cables after having uncabled the suspect battery.
[center]*[/center]
Fly Fishermen have longer rods.
