Hi all
I have purchased some LED replacements for the interior lights of my H2.
The map lights and the ceiling lights were an easy swap out.
The door lights are an issue.
The LED lights do not fit into the end opening of the light housing. My only choice seems to be to remove the clear lens from the plastic housing but I cannot seem to get them separated and I am wondering if there is a trick to getting the clear lens off of the housing or are they glued together?
I hope the pictures help to show what I am trying to explain and I hope someone has a solution for me.
Thanks in advance
J.Carroll
Door interior light housing
- JCarroll
Hey you in the Smart Car....check your rear view mirror and admire my grill.
- JCarroll
Re: Door interior light housing
So I found out that the clear lens is in fact glued to the housing.
With a box cutter I was able to get the lens off with minimal cracking.
On the next nice day I will finish installing the LEDs and post a pic because so far it looks awesome.
