H3 electric mirror
Archngel
H3 electric mirror
Post by Archngel »
Hi , question of the day , anyone H3 owner had a problem with their electric mirrors?
mine at the beginning of the week intermittently didn't work from the Driver switch. now today they dont work at all, neither sides. Ive looked at the conduit in the door, looked at the fuse, im left to rip off the switch from the armrest and see if there is anything there that can be faulty.
Anyone else has an idea?
johnnyspikesH3
Re: H3 electric mirror
Post by johnnyspikesH3 »
Not yet Marc . I would think it would be wheeling oriented . ( Something loose or H2O oriented) ..... Yell ...KEVIN !!!!
Last edited by johnnyspikesH3 on Sat Jun 30, 2012 5:53 am, edited 1 time in total.
gram
Post by gram »
i had this problem. it ended up being where the harness plugs into the drivers door. it had some green corosion. some contact cleaner and di-electric grease and she was as good as new.
