H2 Rear Springs
BRUTE
H2 Rear Springs
Post by BRUTE »
Can the rear springs from a 2500HD be used on an H2 ?
Thank you in advance
BRUTE
Re: H2 Rear Springs
Post by BRUTE »
Let me go one step further and ask do the 2500s even use coil springs or are they using a leaf set up ?
gram
Re: H2 Rear Springs
Post by gram »
I have never seen a 2500 or f-250, or a 2500 ram with coil springs. The load capacity just isnt there with coil springs. Air bags yes. But im assuming you want to get rid of those?
Autumn Walker
Re: H2 Rear Springs
Post by Autumn Walker »
The 2500HD uses leaf springs in the back.
There are a TON of sites offering airbag to coil spring kits for the H2 as well as replacement coil springs if that is all you need. I'm looking to run helper airbags inside my factory coils for when I am trailering a heavy load. I think that is the best of both worlds.
2007 HUMMER H2
