1999 Hummer H1 wiring diagram
slowbutsteady
Post by slowbutsteady »
Hello All,
   I purchased the 1999/2000 parts and service CD (AM General original) but it does not have the wiring diagram on it. The 1997/1998 CD does but the wiring is not the same. Where can I get a set?
Re: 1999 Hummer H1 wiring diagram
I have paper copies if needed. what area are you needing help with?
[quote="slowbutsteady"]
Hello All,
It should be in the service section, if there is a specific area that you need, let me know and should be able to send you a copy..
GreenMeanie
Post by GreenMeanie »
Check the very end of section 12
