Not sure how many of you guys put HIDs into your rig but I always do! I love this lite!
anyways if you did and you are looking for replacement bulbs, I ahve found this guy on ebay to be cheap and will take under $40 for a set of bulbs.. cheaper then local. They are good quality and I am using them in both my JAG and my Hummer.
http://search.ebay.ca/_W0QQsassZhidcanada
he is also in Canada, not cross border bull $hit
HID BULBS ANYONE???
- dizzy
Re: HID BULBS ANYONE???
Are you using the 6000k in your Hummer Derek?
[quote author=dizzy link=topic=471.msg3371#msg3371 date=1215058670]
yep..
I use the 9000K on my Jaguar and they are a bit too blue / purple, I like the 6000K,
yep..
- radak99
Are they just plug and play or do you have to modify the factory wiring harness or install any other hardware?
completely plug and play, about 20 minutes worth of work, only because I taped the wires in with the OEM, looks mint and of course works GREAT
- pink
[quote author=dwaxman1 link=topic=471.msg3565#msg3565 date=1215523883]
umm but you did use the term "Work"...lol
you dont have to connect them to the OEM???
there is a bit of work, it is not as bad as it seems...
[quote author=crebbin link=topic=471.msg3612#msg3612 date=1215624493]
Just in case some of us have not done our HID homework, HID bulbs require HID systems to run; a ballast and appropriate wiring. You can't install a HID bulb in a non HID application.
Another consideration when buying HID bulbs is their location of manufacture. Chinese bulbs are cheap but they are also cheaply made compared to the Japanese ones. I can not comment on how this relates to long term use and reliability.
I have the whole kit, yes it is Chinese but I love it!!! No issues at all....
- Stevegt
Can you still use your hibeams?
