I would like to find out if any one would be interested in a similar setup.
I do realize the this is not a new concept and has been successfully done before.
What I don't like about the systems I've seen, is all the custom modifications that have to be made to the existing suspention components. I'm not a fan of all the cutting and welding to engeneered components. Not to mention the time and cost.
What I am trying to accomplish is an air bag replacement for the stock springs that maintains all the original mounting points, load bearing surfaces and orginal hardware. I also want to maintain a respectable air pressure to avoid unnessary stress on the system.
I currently have two different design concepts, one could utilize several different shocks and the other would be limited to one specific shock with a slight (manufacturer approved) modification. I have also made allowances for an integrated suspention height sensor that could be configured to work with several different preexisting programable air suspention controllers.
I am currently in contact with Firestone researching the bag type and size to achieve the optimal "sweet spot" for the weight and suspention travel of the H1. The different spring rates front and rear are proving to be a tricky match. But no fear I may have a solution.
I'm obvously not going to be able to share every detail on here but I am interested in any suggestions, input, or concerns any of you may have. Not to mention if there is already a system like this out there please let me know as buying one off the shelf would be a tad quicker, easier and cheaper than the journey I have embarked on.
This is going to be a long road so if you want one don't get excited yet.
Ok let the session begin.
All are welcome. Suggestions. Coments. Complements. Complaints. Insults. Nay-Sayers. Bring it on, everything said will breed a better product. Even if only one is ever made.... For me.
