Show'n Shine, BBQ,Meet and Greet-- Aug 2,2014
Here is a great place to Post events in your Area!!
Re: Show'n Shine, BBQ,Meet and Greet-- Aug 2,2014
Well , only a hand-full that can make it.
Still on as a meet and greet/BBQ/ wrenching day.
Still no word from our site owner as per emails and phone calls. Where did he run to this time????
If you are needing some work done, please advise me as per your wants/needs so I can arrange time and space.
Thanks to all whom will make this day .
need to make new standoff for antenna min 1" sq or round steel or aluminium stock by 4 " lenght center drilled and two attachment holes one with threads on top surface.
lets keep this a mechanical event not a machine shop .I will try if time permits to do this one.
Toxicrider
Post by Toxicrider »
Excellent, have some new high clearance rear shock mounts that I need to install so will bring them along with me on Saturday!! Looking forward to seeing folks!!! Also want to discuss a weekend trip up to Ardbeg for some time in late September/early October.
I guess I will have to get a truck out of my hoist, unless we can do it on the ground
Toxicrider
Can be done on the ground, just need two jacks to put on the springs to lift the axle up to stabilize it.  Replacing u-bolts when I put on the new mounts.  BTW, if any of the H3's showing up want I will have a rear set of Hunner skids I will be removing that can be had for a good price!
Just giving aheads up need to take off piece for measurements then either leave you to make it or if you look away I can do it with your shop.
Funny man. Sorry, nobody uses the equipment. Its what I make my money with!
Heading out to get the weekend supplies.I am hoping for more drop ins as the day goes. See you all soon. :wavey:
Toxicrider
See you tomorrow!!! Looking forward to seeing folks!
