Hi Mike,
There is a tutorial and their forum is helpful BUT overall you will own it so you can make changes and keep adjusting the tuning until you have it exactly the way you want it! I have experience with the software and it still took me 3 months to get it close to where I wanted it and I am still refining it. Remember you will need time to run the changes to validate whether or not you made a change for the better or worse.
Hope this helps!
ECU programmers
Re: ECU programmers
Re: ECU programmers
Good info Kev, chat with you soon
Re: ECU programmers
Hi Guys,
Some other very important points to consider;
Without some lower gears and some other key mods, I don't think you will be able to get 15L/100km or Under. I do think that 18L/100km should be doable and maybe a tad Under.
BUT, before you tune you need to do some other stuff first!
A Snorkel would probably improve you mileage up to 10% if combined with intake system.
NGK Iridium Spark Plugs could get you up to another 10%
Some High Performance Coils from <a href="http://performancedistributors.com/prod ... -coils/</a> would allow you to really get some good power.
Remember you will have a Huge Increase to Power so as long as you can control yourself You will See major improvements, if you drive it like you stole it, you will still see an improvement but just not as much!
Under most conditions my H2 that weighs just Under 9000lbs I can run 15 to 17L/100km (Speeds up to 110km/h), but if I back the speed back a bit I can easily run 10 to 11L/100km at around 90 to 100km/h. At 70km/h I run 7 to 8L/100km depending on the highway and road conditions
So yes you can make a major improvement BUT it requires more than just a tune!
Hope this Helps,
Hope this Helps,
- Autumn Walker
Re: ECU programmers
Sign me up... holy shit.
2007 HUMMER H2
- Big_Dub
Re: ECU programmers
PB wondering why you prefer the NGK iridium plugs? The factory ones were AC delco platinum these are no longer available and an SB went out to use AC delco Iridium plugs. Question is what makes you prfer NGK over AC delco Iridium plugs?
Re: ECU programmers
I have tried and tested every single plug on the market in my vehicles and I have never had any plug come close to such repeatable increase to power and mileage! The only plug that was ever a very strong contender was the AC Delco Rapidfire...then they redesigned them and they sucked after that! Trust me no matter what the engine NGK Iridium is KING!PB wondering why you prefer the NGK iridium plugs? The factory ones were AC delco platinum these are no longer available and an SB went out to use AC delco Iridium plugs. Question is what makes you prfer NGK over AC delco Iridium plugs?
E3 spark plugs only work well in Snowblowers or Chainsaws, but no real good results in our engines!
Bosch Plugs are very disappointing and I have had several experience gap closure! IE: the platinum extrudes out and touches the electrode and then no spark!
AC Delco are a great plug but you won't see the mileage and the driveability of the NGK Iridium!
Champion...well that they are not! They just plain SUCK!
- yevych
Re: ECU programmers
Hey Kev, where did you learn about tunning? Where would you suggest to start? I looked at HPTunners forum and people talking some rocket science that looks scary...
