Hi everybody, since the H2 is 6 feet 6 inches tall, I was wondering if anybody knows about coil over spring for the H2.
If I am not mistaken, you can adjust the vehicle height using coil over spring.
I feel that the H2 has to be lowered about 1 to 2 inches max in order to go inside the condo garage safely.
Coil over spring for H2
- njlondon
Re: Coil over spring for H2
Is the roof rack one that can be removed?
- WIBS
Coil over spring is the type of spring that can be adjusted so that the car can be lowered or raised by turning a dial on the spring, but the car has to jacked up first in order for the spring to be adjusted
