Hello, everybody!
My front big side roof marker is not working, so I decided to replace burnt bulb. What kind of Sylvania bulb should I use for this replacement. Different sources said different numbers.
Any ideas what number of bulb it should be?
Thank You.
Side big front roof markers
- collega
Hummer,like nothing else!
- citiboy
Re: Side big front roof markers
As per owners manual, you need bulb 194.
https://drive.google.com/file/d/0B9jQ-XIN5GaPeFA1WFJOMDFSOTQ/view?usp=sharing
<div> </div>
<div> </div>
- collega
Thank You very much! I found it from Sylvania web-site too. I don't know why, but I downloaded 2003 Hummer H2 owner's manual in PDF format and it's said that for roof markers center and corner you need bulb 168 for both! Probably they did mistake! In your source it said that corner roof markers are 194 and just center markers are 168. But you are already second person who told me the same, so it's good to ask and to check! I think it's a mistake in that PDF owner's manual!
