Quebec Rally Pre-Pre Runs May 9th, 2015
Here is a great place to Post events in your Area!!
The Quebec Rally in May is fast approaching so we need to get out and run some of the new trails to make sure the are ready for the Rally.
I need at least 2 other well equipped Hummers to run the trails with me so that we can make sure that we won't have any surprises during the rally!
I am hoping to run some trails on May 9th.
This will not be a stop and smell the roses trail...this will be hardcore cover as much trail as possible before the rally!
So if you are in, make sure to post below!
We will meet at the Tim Horton's in Saint Sauveur from 8:00am and then head up to the trails from there.
Hope you guys are ready!!
citiboy
Re: Quebec Rally Pre-Pre Runs May 9th, 2015
Post by citiboy »
I can go on the 9th.
<div> </div>
Is this why you wanted the tractor at your shop till May?? >:D
[quote="Roy"]
But you said you needed to test the Beast...I was just trying to 'Help' you out!!!
Ok This will be on the 9th and I will also have a very experienced guide from the Jeep club with us as well!
Archngel
Post by Archngel »
I will see if i can make it on the 9th, lots to do on the few first weekend of may
I am out! Still gonna be putting the bottom end of my engine back together!
Check with TC to see if he can run with you guys! You will need the maps from the federation website!
