Hi there,
I have 4x 39.5x13.50R17 Interco Radial Iroks that I am looking to upgrade to the 41x14.50R17 version. Tires have around 4000 miles on them. Around 3000 miles in 2013/14 winter rotated and <1000 miles in the 2014/15 winter (truck being built up). Entirely winter/cold weather driving and 99.9% on road use. Never seen Rock, Mud or Sand. Never a flat, never a cut, never a single issue. Balanced up really nice and I have been really impressed with them. I am looking at doing a custom bed rack and need the 5th tire, but I am leaning more towards the 41", so I thought I would check interest on here before Kijiji. Tires have very little wear and have worn very evenly. I am super impressed with their winter handling. That's why I am buying them again. I can measure tread depth and get photos soon. Looking for $1700. 4 new from 4 wheel parts is $2700 before tax.
I had brand new 3.08 diffs with Torsen II's. I then built up the differentials with Auburn lockers and 2.73 gears. Now The left over parts that I have are: 2x brand new Torsen II's for ABS model trucks, 2x brand new 3.08 Ring and Pinion sets and also the ring and pinion shim sets. Looking for: $550 for both 3.08 sets ($880 USD new), $1200 for both Torsen II's ($1800 USD new) and if someone needs shims let me know. I paid over $300 just for these shims.
I have 3 Rubberduck gauges, which I got for my truck and decided to go a different route. They are identical to the ones on their site here: http://www.rubberduck4x4.com/store/pc/Hummer-H1-Gauges-Monitoring-c99.htm
The gauges are the Boost, EGT, and Trans Temp gauge. The EGT thermo coupler is NOT included nor is the Trans Temp Sensor (RD sells them separate). I installed in my truck and all gauges work 100%, but I am doing something else. Once I had the sensors installed I never rebought them or took them out. These can be sourced elsewhere and aren't specific to the gauges. The Boost has all required parts. Looking for $140. Cost me $200 USD.
I have a 2" Alpha blockout panel for the rear bumper. I installed, used for a year, and redid a custom rear bumper that no longer requires the panel. Looking for $80. Cost me $130 USD.
If the prices are too much for you that's fine. I import my own parts, pay exchange and am in no certain rush to sell any of these parts. If these can help someone out getting a better deal then better on your truck then in my storage. I will get photos as I get the opportunity.
39.5 Iroks, Torsen II's, 3.08's, RD gauges, Alpha panel
- hithere
Re: 39.5 Iroks, Torsen II's, 3.08's, RD gauges, Alpha panel
You are in SK? Have to check freight on some of these parts
- hithere
I am located in saskatchewan. If I have some flexibility I can ship out of yorkton sk. They have depots for jays and dhl. Others as well. Also open to trading for some 12ks people have lying around.
- hithere
All 4 Iroks are measuring 18/32" or 9/16" tread depth. They all are very evenly worn and the Interco website claims 21/32" to be brand new depth. Photo shows 9/16" reading.
I have photos of all parts, but the forum won't let me post that many. You can text or call Kyle for more photos/info. 306.740.8437.
You can post that many, just have to down size the pixs
Sucks, I was looking for 39.5 couple months ago...settled for bias iroks.... wish I knew of those
- hithere
For more photos check out the hummermarketplace.com. I posted those prices in usd. These are cdn.
- drm
I would be interested in trading for the 3.08 gears and shims. I have 4 brand new 12k rear axles so you would need a centering kit for the for the front diff. or you could just put 2 in the rear. if your interested let me know. thanks.
- hithere
Give me a call or email me @ kyle.herperger@gmail....... I am interested in 12k shaft trades, am general tailgates in good shape or 41" iroks
- hithere
Rubberduck gauges are sold. I am currently ordering 12k conversion so if any 12k trades please contact me ASAP. I am interested
