Recommended tire pressure bf Goodrich KO hummer h2
eebh2
Post by eebh2 »
What is the recommended tire pressure on hummer h2 with bf ko tires. Currently Iam using 39 psi and just was curious what everyone is using?
Re: Recommended tire pressure bf Goodrich KO hummer h2
Base it on the rating of the tires.... Some need higher pressure, but when I had the BF's I ran 46 if I remember right and aired down to 22-24 when off roading. My Deuce had 37's..
Check out my write up that gives loads of useful information for this exact topic;
http://www.canadianhummerclub.com/forum/index.php?/topic/4967-fuel-mileage-boosting-tricks-and-tips-that-actually-work/?hl=tips
Thanks,
