Quebec Fall Runs
Here is a great place to Post events in your Area!!
Re: Quebec Fall Runs
Ok so for the day we choose whether it is the 21st or 28th we can opt for several types of trails.
We can run mostly mud with some really steep climbs with some rock ledges.
We can run a tight and twisty muddy offcamber trail with some tight squeezes between some big rocks but no real rock crawling.
We can run some tight forest trails with some very technical climbs to the top.
We can run one of 3 completely new trails that even I have not run yet...only traced out on GPS...but from what I hear from some of my Jeep Buddies are absolutely awesome!
Or we can run a full out Rock Trail that most H3s could dance thru with 35s but will need the occasional winch for the odd ledge. For us H2s, it is one of my favorite new trails. The upper boulder section will require a strong winch and good line choices since there are large trees dotted in the boulders BUT multiple lines depending on the challenge one wishes to take!
Most of these trails are about 1-1.5kms long with the longest at about 4km. The 1-1.5km trails are more technical from start to finish...with a solid crew where every truck has a winch and some good tires we should be able to run 1 in the morning and 1 in the afternoon.
The new trails are in no way a leisure cruise and will challenge both Hummer and Driver throughout. All of the above trails can be run without rock armor but requires aggressive tires and patience. A winch would be a major benefit!
If we choose to run one of the 3 new trails...we will walk it out FIRST to make sure we can actually fit!
Looking forward to a Stellar Last Run before the end of the season!!!
Roy, think you could bring the silver H1???
Ok so I think I will pick the date!
November 21st!
I already have Roy and Marc...Jimmy can you try for the 21st instead of the 28th???
H3 guys? ??? C'mon you will love it!!
As well, we can go to dinner after, kinda like a little Christmas party!
