No Affiliation. I didn't know Hummer made these. If you are in Kitchener cant really go wrong for this price.
http://www.kijiji.ca/v-electronics/kitchener-waterloo/hummer-dc-to-ac-800w-dual-output-power-inverter/1126724581?enableSearchNavigationFlag=true
Hummer Power Inverter
Re: Hummer Power Inverter
It's cheap enough,
Seems like china has learned to print labels. I would have serious doubts if that was made by Hummer. Appears to be a modified sine wave converter at best. Not good for running any kind of electronics that make use of voltage regulators but probably OK for lights and tools.
- Skenth
Could I use this type of power inverter to connect a cabin heater that uses 110V. I've seen marine type heaters but they use 110V. Will it work if I connect to the power inverter? What should i look for in a power inverter for the purpose i want? I'll be turning on the electric cabin heater only when vehicle is running so interior gets warm in the winter
Sonny Kenth
96 Hummer H1 4 dr Hardtop w slantback
