Db2 injection pump
Db2 injection pump
More so curiosity for down the road,,,,,
How many hours labours (basically ) to replace an injection pump,. N/a
I don't mean POlarbears 1/2 hr time frame, either heheh I mean us mortals, ;)
Also does one have to remove the n/a intake, or can ya squeak out the pump?
Seems close.....lol....
Re: Db2 injection pump
For a total newbie...you will have a really fun time replacing it!
You need to remove the intake manifold completely and all fuel lines. Some will tell you that you don't have to remove the fuel lines completely but I am telling you to remove them completely so that you won't have any collateral damage aka a bent and broken fuel line.
You need to remove the oil filler tube to be able to access the three small bolts that hold the drive gear on the injection pump...be careful they can fall down inside the cover...and then you would start /"$%?&*|||"/$"/$/$% so take your time and use a magnet and a deep socket to make sure you have them safe!
You need a special wrench for the three injection pump bolts and for the fuel lines...make sure you have them first!
Ideally at a leisure pace you should be able to do in and out in about 8hours!
Or I could do it for you in 15 minutes with one hand tied behind my back! LOL! :coffeespit:
Lmao....see.....exactly what I thought you'd say, hhehehe
I know...,,in pitch black, no light, hehe
With only a paperclip as my only tool!!!
You do realize that I am only joking with you!! Right? :umno:
ddgermann
Post by ddgermann »
Look on the bright side Monk.... at least you dont have all the turbo and intercooler crap to deal with as well. That might add 2.5 minutes to Kev's time....   :cheers:
Ohh no, kidding?
I see you softened up, I though most diesel gurrus used to pop off bolt with just there knuckles,,,
Hehhee
Ya true, less stuff to come off, with n/a
I'll try to keep the glass half full mind set..., hehe
I don't need to use my knuckles...I can remove them just by giving them an Angry Stare!! >:(
Normally they just jump right into my hand!
Lol!
I went to bring my truck home today , (I'm sure do to me not having proper tools)
My injection pump timing line somehow wiggled back to "normal " the lines matched..... And it was 1/8 ahead,,,
Now I had zero turning the wrench room, but will turn my pump again later today (before -20 pulls in)
Gonna buy a ratchet wrench, it will help me tighten more, I really want to hold off this job for at least couple more months,
Lol , so much I wanna do and seems like in the cold everything, wants changing....
I'm hopping if advance timeline things will be fine,..,, well at least for couple months,....
I the shop tested my lift pump and said 6lbs... So that was good news
Get the real GM Diesel Injection Pump Wrench, it will be worth the investment!
http://www.amazon.ca/OTC-6087-Injection-Pump-Wrench/dp/B000Q6U28S
Hope this helps,
The Diesel Whisperer
