If anyone wants to learn about working on an H1 / humvee , every weekend I will be slowly rebuilding my 84.
There is :
sub frame member,
A frames,
springs,
spring frame mounts,
gas tank straps,
fuel lines,
brakes-complete...lines, caliper, e brake,
wiring,
body work,
exhaust,
oil leaks.
Some of the parts will be new, and some will be removed from my 96 parts truck
Please call in advance so I know you will be there.
Humvee Rebuild Workshop /Wrenching Party
Re: Humvee Rebuild Workshop /Wrenching Party
This weekend im busy, but I'd be down for getting dirty sometime , always a good time !!
I got to see the victim to be done today, while I was getting a brake leak issue fixed
When done its gonna be a fun toy it looks like
Well , after some thought, I think I will do a frame switch with my 96 parts truck.
This will save :
--a lot of ugle works taking the super rusty bolts off.
--time of replacing all 8 a frames, 4 spring, spring mounts, 2 sub frames...
I get to start from the ground and work up.
Start with geared hubs, springs,steering,brake lines, fuel lines, and some paint to make a rolling frame.
Next, the drive line, rad,fuel cell and finish the other lines.
... body change, electrical.......
This will save :
