Headlight rubber vibration rubber
Open to the public and everyone to view, a general area to just chat about anything...
Is AM generals just a threaded short rod with a flat disc glued to a rubber round 3/4 piece?
Like I have a passenger side headlight light wobbling a bit and after inspecting I seen the bottom rod/disc piece came off the rubber isolator
Just for now, I put a fatter screw in from the back to the rubber isolator, lol holds good, (till I get some proper ones off Roy's later)
But seems those suckas on my truck aren't the best quality,....
I'm not sure if mine were some China item, or what....
To picture it, it's like 1/2" long rod welded to a quarter size steel disc then glued (guessing) to a (3/4 deep by 1-1/4" ) round rubber and opposite side same disc then rod
I guess I just figured that the steel would be imbedded more into the rubber
ddgermann
Re: Headlight rubber vibration rubber
Post by ddgermann »
MIne were boned and the rubber separated when I tried to get them apart a couple years ago. Many years of unlubricated service.....
Yup.... not the most "Canadian" winter friendly design Monk.
DG
yrs they are a weak point on the air compressor and headlights. But, I keep them in stock in case you want to fix that wobblie eye thing.
