Hello All,
My h1 is my daily driver. My hummer has a bad tramission and likely a connection problem between the computer and transmission. The transmission slips in first gear badly and the transmission oil is burnt.
The vehicle is basically undriveable. I'd like to tow it to a mechanic in Ontario to be fully serviced and a made a reliable vehicle. It's generally been pretty good before this.
I don't know who services them anymore and I do need it asap. Please let me know if you can do this.
Need a hummer h1 mechanic
- WIDELOAD
Re: Need a hummer h1 mechanic
Send it to Roy...he can fix Everything!
Sounds like a burnt transmittion, take it to a trany shop, then after this is fixed, Phil or myself are the ones to see for maintenance.Phil is 1.5 hours closer than I am, but still a minimum of 1.5 hrs drive one way
- WIDELOAD
James
1995 Hummer H1 Wagon
- slowbutsteady
Thank you so much for forwarding this! I contacted the seller immediately.
That's great for new..
thats 1875 Can plus shipping and brokersge. Try a rebuild price at a trany shop
- humtek
Rebuild transmission 3000 $
All in. Trans , labour , fluid
Call Phil 905 584 9448
