OBD 2 Hummer Codes Part 2
OBD Codes:
P0337  Crankshaft Position Sensor A Circuit Low Input
P0338  Crankshaft Position Sensor A Circuit High Input
P0339  Crankshaft Position Sensor A Circuit Intermittent
P0340  Camshaft Position Sensor Circuit Malfunction
P0341  Camshaft Position Sensor Circuit Range/Performance
P0342  Camshaft Position Sensor Circuit Low Input
P0343  Camshaft Position Sensor Circuit High Input
P0344  Camshaft Position Sensor Circuit Intermittent
P0350  Ignition Coil Primary/Secondary Circuit Malfunction
P0351  Ignition Coil A Primary/Secondary Circuit Malfunction
P0352  Ignition Coil B Primary/Secondary Circuit Malfunction
P0353  Ignition Coil C Primary/Secondary Circuit Malfunction
P0354  Ignition Coil D Primary/Secondary Circuit Malfunction
P0355  Ignition Coil E Primary/Secondary Circuit Malfunction
P0356  Ignition Coil F Primary/Secondary Circuit Malfunction
P0357  Ignition Coil G Primary/Secondary Circuit Malfunction
P0358  Ignition Coil H Primary/Secondary Circuit Malfunction
P0359  Ignition Coil I Primary/Secondary Circuit Malfunction
P0360  Ignition Coil J Primary/Secondary Circuit Malfunction
P0361  Ignition Coil K Primary/Secondary Circuit Malfunction
P0362  Ignition Coil L Primary/Secondary Circuit Malfunction
P0370  Timing Reference High Resolution Signal A Malfunction
P0371  Timing Reference High Resolution Signal A Too Many Pulses
P0372  Timing Reference High Resolution Signal A Too Few Pulses
P0373  Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374  Timing Reference High Resolution Signal A No Pulses
P0375  Timing Reference High Resolution Signal B Malfunction
P0376  Timing Reference High Resolution Signal B Too Many Pulses
P0377  Timing Reference High Resolution Signal B Too Few Pulses
P0378  Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379  Timing Reference High Resolution Signal B No Pulses
P0380  Glow Plug/Heater Circuit "A" Malfunction
P0381  Glow Plug/Heater Indicator Circuit Malfunction
P0382  Exhaust Gas Recirculation Flow Malfunction
P0385  Crankshaft Position Sensor B Circuit Malfunction
P0386  Crankshaft Position Sensor B Circuit Range/Performance
P0387  Crankshaft Position Sensor B Circuit Low Input
P0388  Crankshaft Position Sensor B Circuit High Input
P0389  Crankshaft Position Sensor B Circuit Intermittent
P0400  Exhaust Gas Recirculation Flow Malfunction
P0401  Exhaust Gas Recirculation Flow Insufficient Detected
P0402  Exhaust Gas Recirculation Flow Excessive Detected
P0403  Exhaust Gas Recirculation Circuit Malfunction
P0404  Exhaust Gas Recirculation Circuit Range/Performance
P0405  Exhaust Gas Recirculation Sensor A Circuit Low
P0406  Exhaust Gas Recirculation Sensor A Circuit High
P0407  Exhaust Gas Recirculation Sensor B Circuit Low
P0408  Exhaust Gas Recirculation Sensor B Circuit High
P0410  Secondary Air Injection System Malfunction
P0411  Secondary Air Injection System Incorrect Flow Detected
P0412  Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413  Secondary Air Injection System Switching Valve A Circuit Open
P0414  Secondary Air Injection System Switching Valve A Circuit Shorted
P0415  Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416  Secondary Air Injection System Switching Valve B Circuit Open
P0417  Secondary Air Injection System Switching Valve B Circuit Shorted
P0418  Secondary Air Injection System Relay "A" Circuit Malfunction
P0419  Secondary Air Injection System Relay "B" Circuit Malfunction
P0420  Catalyst System Efficiency Below Threshold (Bank 1)
P0421  Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422  Main Catalyst Efficiency Below Threshold (Bank 1)
P0423  Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424  Heated Catalyst Temperature Below Threshold (Bank 1)
P0430  Catalyst System Efficiency Below Threshold (Bank 2)
P0431  Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432  Main Catalyst Efficiency Below Threshold (Bank 2)
P0433  Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434  Heated Catalyst Temperature Below Threshold (Bank 2)
P0440  Evaporative Emission Control System Malfunction
P0441  Evaporative Emission Control System Incorrect Purge Flow
P0442  Evaporative Emission Control System Leak Detected (small leak)
P0443  Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444  Evaporative Emission Control System Purge Control Valve Circuit Open
P0445  Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446  Evaporative Emission Control System Vent Control Circuit Malfunction
P0447  Evaporative Emission Control System Vent Control Circuit Open
P0448  Evaporative Emission Control System Vent Control Circuit Shorted
P0449  Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450  Evaporative Emission Control System Pressure Sensor Malfunction
P0451  Evaporative Emission Control System Pressure Sensor Range/Performance
P0452  Evaporative Emission Control System Pressure Sensor Low Input
P0453  Evaporative Emission Control System Pressure Sensor High Input
P0454  Evaporative Emission Control System Pressure Sensor Intermittent
P0455  Evaporative Emission Control System Leak Detected (gross leak)
P0460  Fuel Level Sensor Circuit Malfunction
P0461  Fuel Level Sensor Circuit Range/Performance
P0462  Fuel Level Sensor Circuit Low Input
P0463  Fuel Level Sensor Circuit High Input
P0464  Fuel Level Sensor Circuit Intermittent
P0465  Purge Flow Sensor Circuit Malfunction
P0466  Purge Flow Sensor Circuit Range/Performance
P0467  Purge Flow Sensor Circuit Low Input
P0468  Purge Flow Sensor Circuit High Input
P0469  Purge Flow Sensor Circuit Intermittent
P0470  Exhaust Pressure Sensor Malfunction
P0471  Exhaust Pressure Sensor Range/Performance
P0472  Exhaust Pressure Sensor Low
P0473  Exhaust Pressure Sensor High
P0474  Exhaust Pressure Sensor Intermittent
P0475  Exhaust Pressure Control Valve Malfunction
P0476  Exhaust Pressure Control Valve Range/Performance
P0477  Exhaust Pressure Control Valve Low
P0478  Exhaust Pressure Control Valve High
P0479  Exhaust Pressure Control Valve Intermittent
P0480  Cooling Fan 1 Control Circuit Malfunction
P0481  Cooling Fan 2 Control Circuit Malfunction
P0482  Cooling Fan 3 Control Circuit Malfunction
P0483  Cooling Fan Rationality Check Malfunction
P0484  Cooling Fan Circuit Over Current
P0485  Cooling Fan Power/Ground Circuit Malfunction
P0500  Vehicle Speed Sensor Malfunction
P0501  Vehicle Speed Sensor Range/Performance
P0502  Vehicle Speed Sensor Low Input
P0503  Vehicle Speed Sensor Intermittent/Erratic/High
P0505  Idle Control System Malfunction
P0506  Idle Control System RPM Lower Than Expected
P0507  Idle Control System RPM Higher Than Expected
P0510  Closed Throttle Position Switch Malfunction
P0520  Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521  Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522  Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523  Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530  A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531  A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532  A/C Refrigerant Pressure Sensor Circuit Low Input
P0533  A/C Refrigerant Pressure Sensor Circuit High Input
P0534  Air Conditioner Refrigerant Charge Loss
P0550  Power Steering Pressure Sensor Circuit Malfunction
P0551  Power Steering Pressure Sensor Circuit Range/Performance
P0552  Power Steering Pressure Sensor Circuit Low Input
P0553  Power Steering Pressure Sensor Circuit High Input
P0554  Power Steering Pressure Sensor Circuit Intermittent
P0560  System Voltage Malfunction
P0561  System Voltage Unstable
P0562  System Voltage Low
P0563  System Voltage High
P0565  Cruise Control On Signal Malfunction
P0566  Cruise Control Off Signal Malfunction
P0567  Cruise Control Resume Signal Malfunction
P0568  Cruise Control Set Signal Malfunction
P0569  Cruise Control Coast Signal Malfunction
P0570  Cruise Control Accel Signal Malfunction
P0571  Cruise Control/Brake Switch A Circuit Malfunction
P0572  Cruise Control/Brake Switch A Circuit Low
P0573  Cruise Control/Brake Switch A Circuit High
P0574  Cruise Control Related Malfunction
P0575  Cruise Control Related Malfunction
P0576  Cruise Control Related Malfunction
P0578  Cruise Control Related Malfunction
P0579  Cruise Control Related Malfunction
P0580  Cruise Control Related Malfunction
P0600  Serial Communication Link Malfunction
P0601  Internal Control Module Memory Check Sum Error
P0602  Control Module Programming Error
P0603  Internal Control Module Keep Alive Memory (KAM) Error
P0604  Internal Control Module Random Access Memory (RAM) Error
P0605  Internal Control Module Read Only Memory (ROM) Error
P0606  PCM Processor Fault
P0608  Control Module VSS Output "A" Malfunction
P0609  Control Module VSS Output "B" Malfunction
P0620  Generator Control Circuit Malfunction
P0621  Generator Lamp "L" Control Circuit Malfunction
P0622  Generator Field "F" Control Circuit Malfunction
P0650  Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654  Engine RPM Output Circuit Malfunction
P0655  Engine Hot Lamp Output Control Circuit Malfucntion
P0656  Fuel Level Output Circuit Malfunction
P0700  Transmission Control System Malfunction
P0701  Transmission Control System Range/Performance
P0702  Transmission Control System Electrical
P0703  Torque Converter/Brake Switch B Circuit Malfunction
P0704  Clutch Switch Input Circuit Malfunction
P0705  Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706  Transmission Range Sensor Circuit Range/Performance
P0707  Transmission Range Sensor Circuit Low Input
P0708  Transmission Range Sensor Circuit High Input
P0709  Transmission Range Sensor Circuit Intermittent
P0710  Transmission Fluid Temperature Sensor Circuit Malfunction
P0711  Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712  Transmission Fluid Temperature Sensor Circuit Low Input
P0713  Transmission Fluid Temperature Sensor Circuit High Input
P0714  Transmission Fluid Temperature Sensor Circuit Intermittent
P0715  Input/Turbine Speed Sensor Circuit Malfunction
P0716  Input/Turbine Speed Sensor Circuit Range/Performance
P0717  Input/Turbine Speed Sensor Circuit No Signal
P0718  Input/Turbine Speed Sensor Circuit Intermittent
P0719  Torque Converter/Brake Switch B Circuit Low
P0720  Output Speed Sensor Circuit Malfunction
P0721  Output Speed Sensor Range/Performance
P0722  Output Speed Sensor No Signal
P0723  Output Speed Sensor Intermittent
P0724  Torque Converter/Brake Switch B Circuit High
P0725  Engine Speed input Circuit Malfunction
P0726  Engine Speed Input Circuit Range/Performance
P0727  Engine Speed Input Circuit No Signal
P0728  Engine Speed Input Circuit Intermittent
P0730  Incorrect Gear Ratio
P0731  Gear 1 Incorrect ratio
P0732  Gear 2 Incorrect ratio
P0733  Gear 3 Incorrect ratio
P0734  Gear 4 Incorrect ratio
P0735  Gear 5 Incorrect ratio
P0736  Reverse incorrect gear ratio
P0740  Torque Converter Clutch Circuit Malfuction
P0741  Torque Converter Clutch Circuit Performance or Stuck Off
P0742  Torque Converter Clutch Circuit Stuck On
P0743  Torque Converter Clutch Circuit Electrical
P0744  Torque Converter Clutch Circuit Intermittent
P0745  Pressure Control Solenoid Malfunction
P0746  Pressure Control Solenoid Performance or Stuck Off
P0747  Pressure Control Solenoid Stuck On
P0748  Pressure Control Solenoid Electrical
P0749  Pressure Control Solenoid Intermittent
P0750  Shift Solenoid A Malfunction
P0751  Shift Solenoid A Performance or Stuck Off
P0752  Shift Solenoid A Stuck On
P0753  Shift Solenoid A Electrical
P0754  Shift Solenoid A Intermittent
P0755  Shift Solenoid B Malfunction
P0756  Shift Solenoid B Performance or Stuck Off
P0757  Shift Solenoid B Stuck On
P0758  Shift Solenoid B Electrical
P0759  Shift Solenoid B Intermittent
P0760  Shift Solenoid C Malfunction
P0761  Shift Solenoid C Performance or Stuck Off
P0762  Shift Solenoid C Stuck On
P0763  Shift Solenoid C Electrical
P0764  Shift Solenoid C Intermittent
P0765  Shift Solenoid D Malfunction
P0766  Shift Solenoid D Performance or Stuck Off
P0767  Shift Solenoid D Stuck On
P0768  Shift Solenoid D Electrical
P0769  Shift Solenoid D Intermittent
P0770  Shift Solenoid E Malfunction
P0771  Shift Solenoid E Performance or Stuck Off
P0772  Shift Solenoid E Stuck On
P0773  Shift Solenoid E Electrical
P0774  Shift Solenoid E Intermittent
P0780  Shift Malfunction
P0781  1-2 Shift Malfunction
P0782  2-3 Shift Malfunction
P0783  3-4 Shift Malfunction
P0784  4-5 Shift Malfunction
P0785  Shift/Timing Solenoid Malfunction
P0786  Shift/Timing Solenoid Range/Performance
P0787  Shift/Timing Solenoid Low
P0788  Shift/Timing Solenoid High
P0789  Shift/Timing Solenoid Intermittent
P0790  Normal/Performance Switch Circuit Malfunction
P0801  Reverse Inhibit Control Circuit Malfunction
P0803  1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804  1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
dizzy
Re: OBD 2 Hummer Codes Part 2
Post by dizzy »
Great Information!  Thanks Derek.
