H1 Tire sizes
Boeing Jet
H1 Tire sizes
Post by Boeing Jet »
At the moment I have 38.5x14.50x16.5 tires on stock alloy rims for my H1. I was told the biggest I can go is 40.0x15.00x16.5 without doing any mods to the truck. Is this true? What are the biggest I can put on the truck without doing any mods?
Thanks
Re: H1 Tire sizes
Gunner, i think with 40's you need alift job......Kevin will clear this up right sir K...... <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> <img src='http://www.canadianhummerclub.com/forum ... >/wink.gif' class='bbc_emoticon' alt=';)' />
Re: H1 Tire sizes
Hey Markus,
For the street, no problem the 40s will fit fine, but off-road can you say RUB-RUB-RUB!  <img src='http://www.canadianhummerclub.com/forum ... >/ohmy.gif' class='bbc_emoticon' alt=':o' /> <img src='http://www.canadianhummerclub.com/forum ... >/ohmy.gif' class='bbc_emoticon' alt=':o' /> <img src='http://www.canadianhummerclub.com/forum ... >/ohmy.gif' class='bbc_emoticon' alt=':o' /> The suspension will flex so much that the 40s could possibly damage the air filter housing or even the battery tray. To run 40s safely you need at least new coils and shocks or a body lift. Or you could do both and run 42s! <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> I would go for the 42s <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> Unless you plan to run most of our trails here in Quebec this summer then I would say stick with the 38s!
Re: H1 Tire sizes
[quote author=Boeing Jet link=topic=926.msg6746#msg6746 date=1237924236]
Thanks
Gunner, did you make your choice <img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt='???' /> <img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt='???' />
Boeing Jet
Re: H1 Tire sizes
HA HA HA  If I made my choose I would put a 10" lift then a 2" body lift and then put 52's on the truck. but as it stands now theres a good chance I'll stick with the 38's or max 39.5's. this is what I was thinking.
Interco
Irok 39.5x13.50R16.5LT ROK-08 for $600/per
Super Swampers TSL SX 38.5x14.50-16.5LT SAM-76 $440/per
Pricing is from National 4wd in Burlington Ont.
Anyone has tire contacts?
Thanks
P.S. Told you I play safe. Always have my rubbers
Re: H1 Tire sizes
CALL ME FOR THE TIRE IROK 375 [img width=135 height=78]http://i304.photobucket.com/albums/nn18 ... ce20c7.gif[/img]UNIT JUST CALL BROOOOO........I AM IN THE US NEXT WEEK ...AND I PICKING UP MY TIRES .......
Injunfarian
CHC President
Re: H1 Tire sizes
Post by Injunfarian »
Also with 15" wide tire you will get some rubbing as well.. I have 38x15x16.5" tires on my H1 with 2" suspension lift and wheel spacers and still get some rubbing on tight turns. I plan on going upto 42" iroks soon though.
ucana422
Re: H1 Tire sizes
Post by ucana422 »
I really like the look of the wider tire and was wondering if anyone could tell me how to go about this, do you need new wheels to fit the extra width, or will the wider tires fit on the standard original wheels? I have 37 X 12.5 X 16.5  , and at the moment only 3 , so I need at least one matching replacement or two, and have through reading some of these post begun wondering what the actual original, coming off the assembly line tire size was?
