Tips and Tricks
Tips and Tricks
Remember to Share any TIP and Trick that you find with your trucks.. we all will learn and benefit from this and if we all share together then we will all learn from it..
Tip One..
Bought 24 LED 3157 bulbs off Ebay for my 2005 H2 front signal lights.. the diameter is to large and they will not fit into the housing.. don't waste time or money, unless you want to shave off the plastic on the bulb or housing (not recommended)..
[img width=400 height=480]http://imgs.inkfrog.com/pix/enkmall/315 ... 24_R_2.jpg[/img]
[img width=500 height=500]http://imgs.inkfrog.com/pix/enkmall/3156_3157_24_W.jpg[/img]
Re: Tips and Tricks
Tip two...
Swapped out all my 194 bulbs for LEDs.. they look great and draw lots less voltage.. Highly recommend!!
[img width=400 height=398]http://imgs.inkfrog.com/pix/enkmall/LED_A_2.jpg[/img]
[img width=420 height=420]http://imgs.inkfrog.com/pix/enkmall/LED_R_1.jpg[/img]
[img width=420 height=420]http://imgs.inkfrog.com/pix/enkmall/LED_B_1.jpg[/img]
BrokenPlay
Re: Tips and Tricks
Post by BrokenPlay »
One I am using is for the interior center console and other plastics of the same color.
The metallic charcoal color of the center console, and interior door latch buckets....should you need to repaint them.....I found that Dupli-color Wheel coating CHWP10200 Graphite  to be a near perfect match.
Rob
Re: Tips and Tricks
great call..
Re: Tips and Tricks
DO NOT LINE X ROCK TUBES ...HIT A ROCK AND IT COMES OFF LIKE CHEESE YES CHEESE <img src='http://www.canadianhummerclub.com/forum ... >/ohmy.gif' class='bbc_emoticon' alt=':o' /> <img src='http://www.canadianhummerclub.com/forum ... >/ohmy.gif' class='bbc_emoticon' alt=':o' /> <img src='http://www.canadianhummerclub.com/forum ... >/ohmy.gif' class='bbc_emoticon' alt=':o' />
Re: Tips and Tricks
thanks Tony...
Re: Tips and Tricks
Travis from rubber duck gave me the info........thanks Travis .....rubber duck all the way!!!!!!!!!!!! <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> <img src='http://www.canadianhummerclub.com/forum ... iggrin.gif' class='bbc_emoticon' alt=':D' /> <img src='http://www.canadianhummerclub.com/forum ... >/wink.gif' class='bbc_emoticon' alt=';)' />
