Hello guys!
I put my H2 last night into garage to install a new horns. Gyus there put a horns into my truck, but when I came to pick up a car and pay for installation- they could not get a key out.
The problem: key stucked and they do not come out of the egnition.
I was searching here for solution.
I've red this http://canadianhummerclubforum.com/Foru ... opic=222.0 and that http://www.hummerknowledgebase.com/rungear/h2stuck.html
Than I called a technicians, who taking care of my Hummer and told them what to do (translated everything to Russian). They did, but...however, they couldn't find anything wrong- not a wire, not a switch...
I wander if there are any more possible reasons and solutions that any of you can give as a hint?
Thanks for any advise!
Hummer H2- key stucked
Re: Hummer H2- key stucked
sorry lex, not sure, I will ask some of my guys at the dealer to see if they know..
- Lex
Hi dwaxman1 and everyone!
Problem is resolved!
Suggestions from here http://canadianhummerclubforum.com/Foru ... opic=222.0 helped!
Checking once again technicians found one wire with partly destroyed isulation. It was difficult to see as the upper side of wire looks fine, but the part, which was below, at the base was touching car body and blocking a solenoid (also giving a "check engine" sign on).
Proper isulation of the wire resolved a stucking problem.
Now I'm happily drive my H2 with new horn and even can take a key away!
<img src='http://www.canadianhummerclub.com/forum ... iggrin.gif' class='bbc_emoticon' alt=':D' />
thanks to Dave Bot for the information...we can do anything if we stick together!
Hummer Owners look after Hummer Owners, no matter where they are!
