[quote name='duncanpa' date='14 March 2010 - 10:22 PM' timestamp='1268601740' post='14566']
I am thinking Kev is right as I had the windshield replaced. I will look there first. Already looked through the sunroof at the deflector and everything else up top...all tight and good to go. Kev, without me going out to look, how do those mouldings come off?? Is it relatively easy? What can I do if the idiot took the foam off....silicone??
Just get some self adhesive foam strips from your local auto parts store. Try to get one that would be 3/4 to 1" thick!
Open your front doors, you should see the mounting screws along the inside edge...you will need to pull the rubber moulding down to access them.
Highway Noise
Re: Highway Noise
Re: Highway Noise
[quote name='duncanpa' date='14 March 2010 - 10:24 PM' timestamp='1268601894' post='14568']
Got another one now....just after arriving in Florida, I got another new noise. If I turn on the blower for the AC unit, it makes a rattling sound...almost like some leaves have been sucked into the system. Is this possible?? How do I fix this noise...although it is not nearly as bothersome as the other one.
Sounds like you have a squirrel problem!! <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
No Seriously, on your 05 you should have filters for your hvac ducts. Locate the cover remove the one bolt and pull out the filter and change them, DO NOT CLEAN THEM!! If you don't have a filter, remove the blower motor and vaccum it and the housing it sits in! Both of these should fix the problem! Unless you really do have a squirrel in there!! Or better yet since you are in florida...it could be a tiny lizard!!!
- kevin
Re: Highway Noise
Funny you should say that, I opened my fuse box under the hood and found a pile of opened nut shells
2007 H2 Black
Re: Highway Noise
[quote name='hummer plumber' date='14 March 2010 - 08:30 PM' timestamp='1268616618' post='14577']
WHAT KIND OF NUTS <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' /> <img src='http://www.canadianhummerclub.com/forum ... lleyes.gif' class='bbc_emoticon' alt=':rolleyes:' />
Re: Highway Noise
[quote name='dwaxman1' date='14 March 2010 - 08:49 PM' timestamp='1268617784' post='14579']
I had a squirrel once...
THAT'S RIGHT YOU HAVE NO LUNCH ..SO YOU HAD (ROAD KILL) SQUIRREL <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
Re: Highway Noise
[quote name='duncanpa' date='14 March 2010 - 04:23 PM' timestamp='1268601784' post='14567']
TC...you arrange the interest free financing and I'll buy a new Hummer!!!
<img src='http://www.canadianhummerclub.com/forum ... feSpit.gif' class='bbc_emoticon' alt=':coffeespit:' /> <img src='http://www.canadianhummerclub.com/forum ... adbang.gif' class='bbc_emoticon' alt=':headbang:' /> <img src='http://www.canadianhummerclub.com/forum ... prised.gif' class='bbc_emoticon' alt=':whatever:' /> <img src='http://www.canadianhummerclub.com/forum ... tongue.gif' class='bbc_emoticon' alt=':P' />
Re: Highway Noise
[quote name='Polar Bear' date='14 March 2010 - 04:32 PM' timestamp='1268602343' post='14569']
Kevin <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
- duncanpa
Re: Highway Noise
Derek,
You are the squirrel...the OEM Squirrel....LOL <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
- shotgun-cam
Re: Highway Noise
better a vacant squirrel than an ex cat that warmed himself on engine. When started engine belt took care of cat with much screaming and mess. <img src='http://www.canadianhummerclub.com/forum ... ngsick.gif' class='bbc_emoticon' alt=':sick:' />
